A/C Charging Question - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-19-2013, 09:15 AM   #16
An old Tradesmen
Rewards Points: 6,846
Originally Posted by markharmon View Post
If I get a set of gauges how do I know what the system pressure should be at?
By knowing what the proper super heat and sub cooling is.
Old 05-19-2013, 09:49 AM   #17
Hvac Pro
yuri's Avatar
Rewards Points: 1,778
Can cold suction line
A/C charging question-beer.jpg
The Following User Says Thank You to yuri For This Useful Post:
ben's plumbing (05-19-2013)
Old 05-19-2013, 01:37 PM   #18
Rewards Points: 582
Originally Posted by COLDIRON View Post
The very first thing to know is what type of refrigerant is in the equipment. The next thing to know is what pressures they operate at. The next thing is to buy a set of gages compatible with the type of refrigerant your using. You should also have a set of superheat thermometers, a digital temperature analyzer with 2 leads to check 2 temperatures at the same time. Then you will need a jug of refrigerant the type that's in the unit. Next you might need a scale to weigh in th refrigerant. Now after all that you really shouldn't be putting gages on a unit to check the freon unless you really have done many checks before that. The reason, every time someone puts gages on a unit it losses a couple Oz's of freon which has to be calculated back in to the unit.
Probably should call a pro. Call me now or call me later it'll cost you more later when you F--- everything up.
be nice ben sr
Old 05-19-2013, 02:35 PM   #19
Rewards Points: 1,216
Originally Posted by ben's plumbing View Post
be nice ben sr
OK, I am trying I didn't spell it out I don't want beenthere on my a--.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
The Following User Says Thank You to COLDIRON For This Useful Post:
Old 05-19-2013, 04:44 PM   #20
LOL, the old "beer can method".
I once had someone tell me he used the "headlight method" when I asked what he meant he said he had the homeowners wife stand over a vent & he added until her headlights came on.
JScotty is offline   Reply With Quote
Old 05-19-2013, 04:54 PM   #21
Hvac Pro
yuri's Avatar
That could get you in a lot of trouble nowadays.
Old 05-19-2013, 05:07 PM   #22
how do I find out what pressure my R22 system operates at?
markharmon is offline   Reply With Quote
Old 05-19-2013, 05:23 PM   #23
An old Tradesmen
By finding out the super heat and sub cool temps.
The Following User Says Thank You to beenthere For This Useful Post:
Old 05-19-2013, 05:29 PM   #24
An old Tradesmen
markharmon.
Are you also mikem201, mmiller, and miguel24932.
Old 05-19-2013, 05:36 PM   #25
I'm Your Huckleberry
Rewards Points: 2,270
first and foremost, clean both the evaporator and condenser coils. improper air flow across those and you'll never get your charge right.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 05-19-2013, 08:04 PM   #26
markharmon.
?? who?
Old 05-19-2013, 08:05 PM   #27
How do I find those out?
Old 05-19-2013, 08:47 PM   #28
Start by reading/research, these guys have pointed you in the right direction as a DIY'er it's your job to dig into the books a bit
http://lmgtfy.com/?q=how+to+determin...at+and+subcool
(I'm a DIY'er too, but am mildly annoyed at your questions, tone etc. toward the professionals here and how you portray us)
wheelsup is offline   Reply With Quote
Old 05-19-2013, 09:09 PM   #29
Thanks.
Old 05-20-2013, 12:57 AM   #30
Rewards Points: 1,192
R-22 unit 65 psi suction side, 225 psi liquid side That'll get you cool.
bobelectric is offline   Reply With Quote
Charging battery while using it vs charging till empty will this affect battery life? jratftcc Electrical 2 04-01-2013 10:41 PM
Another Aluminum Siding prep question aribert Painting 6 03-14-2013 01:48 PM
EV charging loads and time switches - rating question flasherz Electrical 4 03-11-2013 01:35 AM
Plumbing for new shower kit question noviceshock Plumbing 6 03-02-2013 08:11 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
