A/C Charge - "Beer Can" Method Vs. Gauges - HVAC - DIY Chatroom Home Improvement Forum
Old 08-19-2012, 08:14 PM   #1
A/C Charge - "Beer Can" Method vs. Gauges
Is checking the the AC lines by temperature "feel" ever wrong?
I've never found a case in either my home or car ACs where the system was cooling properly and one line wasn't "beer can cold" and the other warm to the touch.
Reason I'm concerned is that I just had 2 new 410a SEER 13 systems installed and neither passes the beer can test, although one is markedly better.
I popped the hood on the more anemic of the 2, which isn't putting out much condensate either, and found only the lower half of the A-coil to be cold and sweaty.
I suspect undercharge - what do you experts think?
thatbobguy is offline   Reply With Quote
Old 08-19-2012, 08:23 PM   #2
Rewards Points: 582
need to put gauges on system to be sure as to what is going on....I never guess...even though beer is always cold.
Old 08-19-2012, 08:55 PM   #3
An old Tradesmen
Rewards Points: 7,742
Its vey possible that they aren't fully charged.
I have had many units that the vapor line wasn't anywhere near beer can cold and it was charged properly. All depends on the conditions at the time your checking it.
The Following User Says Thank You to beenthere For This Useful Post:
plummen (08-20-2012)
Old 08-20-2012, 02:43 PM   #4
Bombastic Idiot
notmrjohn's Avatar
Is that American ice cold beer or BTU's? ( British Temperature, Ugh!) Use the gauges and a thermometer, read the tech chart, that's what they're there for. What feels cold to you may just be tepid to someone else. Pumping in gas till it feels right is a good way to blow a hole in a joint or wreck a compressor.
notmrjohn is offline   Reply With Quote
Old 08-20-2012, 08:15 PM   #5
Missouri Bound's Avatar
Years ago when I was just the building maintenance guy I had to let the HVAC guys up on the roof and bring them to the equipment requiring work. Those were the days when the tech grabbed the suction line and let that be his guide as to what to do. Seems like it always worked for them. But that was just their initial check...the guages always came out for the final result. But the "ice cold beer" test is a good start.
Do you want it your way or the right way?
The Following User Says Thank You to Missouri Bound For This Useful Post:
Old 08-20-2012, 10:52 PM   #6
Rewards Points: 268
Good topic. My low side is not that cold. Doesnt sweat. Still have 58* coming out the ducts. Even when its 100* F outside. Is it low on 403 or does it have too much ? Cant be right if the line is not "beer can cold".
JackDidley is offline   Reply With Quote
Old 08-21-2012, 07:00 AM   #7
HOTDAWG
if its warm out you should be at least seeing the suction line sweat
Affordable Comfort, assisting with furnaces Barrie and surrounding area, as well as offering 24 hour furnace repair
Acomfort is offline   Reply With Quote
Old 08-21-2012, 07:23 AM   #8
Houston204's Avatar
Rewards Points: 556
Bad TXV's, failing compressor valves, plugged condenser coils, and return air leaks can cause a warm suction line.
Gauges, meters and thermometers will show these alternate causes.
Houston204 is offline   Reply With Quote
Old 08-21-2012, 07:46 AM   #9
Rewards Points: 268
Its only a year old. No return air leaks. May sweat at the outside unit but I'm not seeing it at the A coil. Kept the house warm last winter when it was 12* F outside.
Old 08-21-2012, 07:57 AM   #10
Houston204's Avatar
Rewards Points: 556
If it has leaked enough refrigerant in a year to stop condensating you should call your installing contractor to repair this under warranty.
Old 08-21-2012, 10:23 AM   #11
New high efficiency A/C units may have a "variable speed" compressor. If just a little cooling is needed, it would run slower. If a lot of cooling is needed, it would run faster.
With that said, I should think if not much cooling was needed and the compressor was running slowly, the pipes would not be very cold/hot.
(Older units are just on/off.)
The question is if they are keeping the house cool?
Billy_Bob is offline   Reply With Quote
Old 08-21-2012, 11:42 AM   #12
[quote=Billy_Bob;993363]New high efficiency A/C units may have a "variable speed" compressor. If just a little cooling is needed, it would run slower. If a lot of cooling is needed, it would run faster.
/quote]
Since I do not know...is that accurate or an assumption? Will the system perform properly with "a little cooling"?
Old 08-21-2012, 02:05 PM   #13
Rewards Points: 268
Keeps the house cool, just fine. I will get some gauges on it if I ever get my storm damage project done.
Old 08-21-2012, 04:17 PM   #14
An old Tradesmen
[quote=Missouri Bound;993411]
/quote]
Only 2 actual manufacturers(ok 3 if you count daikin) have variable speed compressors in ducted conventional split systems.
Both of them will have sweat on the suction line if the indoor VS blower is set up for comfort(low CFMs).
Old 08-22-2012, 08:53 PM   #15
That's interesting - I always thought the blower just ran on 2 speeds, high for A/C and low for heat.
So if the blower speed selected (assuming VS) was too high - no sweat and little condensate?
Would that affect humidity too? My AC doesn't feel as "dry" as I'm used to.
Hot Gas Method for Checking Heat Pump Charge zootjeff HVAC 15 12-03-2011 02:11 PM
Charge line from car to trailer Scardey eCat Electrical 7 10-24-2010 10:38 PM
