A/C Blows Warm Air - HVAC - DIY Chatroom Home Improvement Forum
Old 08-04-2011, 12:27 PM   #1
A/C blows warm air
Hi All,
A couple of nights ago we noticed our A/C was running all night, but not cooling our house. We have strong air flow through the ducts (blower works), but the air is warm. Also, no water is draining out of the condensate drain line. And, the outside compressor fan runs fine (not sure about the air compressor, though).
I replaced the air filter this morning, turned the A/C off, and have been running the fan--thinking it the evaporator coils might be frozen.
With this information in mind, I have three questions:
First, was I incorrect to assume frozen evaporator coils because no water was draining?
Second, how long do I need to run the fan to defrost before I should try the A/C again to see if that is actually the issue? I mean, I don't want to restart too early.
Third, aside from the sound, is there any way I can tell if the air compressor in the outside unit is working properly?
Thanks for the insight!
Walt
walters_12 is offline   Reply With Quote
Old 08-04-2011, 12:55 PM   #2
Rewards Points: 6,652
If the outside unit is doing its job, you will hear a humming/whooshing sound of the refrigerant going through the larger of the lines on the line set, and it should feel as ice cold where the large line enters the outside unit.
Temp outside close by the condenser:
Temp 1st floor:
Temp 2nd floor:
Temp on the return:
Temp just after Evap coil: (inside the duct)
Temp on the supply register close to evap coil:
Temp on the supply register far away the evap coil:
Old 08-04-2011, 03:06 PM   #3
Thanks for the reply gregzoll.
I'm assuming you want me to report the temperatures you requested. I have no way of testing some of these on my own. I can tell you that currently it is about 80F outside and that it is probably a little warmer in the house. It was 82F when I left for work this morning--rain chances kept me from opening windows.
I'm heading home in about an hour to check the unit out, see if it has defrosted, and see if the condenser will turn on. Basically, need to know so I can call a tech before the end of the business day.
Old 08-04-2011, 03:37 PM   #4
If you can get a kitchen thermometer that goes from 0 to 220, it can help measure those temps. I use something like this http://www.bedbathandbeyond.com/prod...p?SKU=10161711 You may have to open up the panel at the a-coil to see if it is freezing up. You can also check to see if the larger line is getting cold, by placing your hand on the lineset where it enters the outside unit.
1000W Dimmer with 715W load getting beyond warm? Badfish740 Electrical 5 05-02-2011 07:23 PM
Kenmore 596 bottom freezer cold top warm klimshelf HVAC 2 03-30-2011 09:32 AM
Dimmer switch is warm even when lights are off! gonzo Electrical 17 05-25-2010 08:10 AM
rheem split system blows warm for five minutes then cold queenie HVAC 1 06-15-2009 06:57 PM
my tile floor is warm minahanna Plumbing 8 01-23-2006 07:04 PM
