A/C Blowing Hot Air After Replacing Capacitor. - HVAC - DIY Chatroom Home Improvement Forum
Old 08-14-2012, 01:28 AM   #1
A/C blowing hot air after replacing capacitor.
Does anyone know what the problem may be after I've replaced a bad capacitor, yet ac still is blowing hot air? Prior to turning on the ac, the room temperature was 83 degrees. Rather than cooling the room, after turning on the ac on with a new capacitor, the room temperature raised to 88 degrees in half hour. I let it run for 6 hours to give the capacitor a chance to start, but no luck. What to do?
Mdelgado is offline   Reply With Quote
Old 08-14-2012, 01:40 AM   #2
I'm Your Huckleberry
Rewards Points: 2,270
You have an electrical tester which test microfarads, to test these caps? To test voltage? Did you wire it in properly? Is the compressor running, the condenser fan?
Thanks.
Doc Holliday is offline   Reply With Quote
Old 08-14-2012, 02:06 AM   #3
Was this a fan capacitor, a compressor capacitor or a dual run capacitor which runs both the fan and compressor?
Is the condenser fan spinning in the right direction, blowing warm air up and out of the condenser?
Thanks.
Replacing capacitor in fan Macro Electrical 3 05-28-2012 07:00 PM
Need help finding specific capacitor! mark2741 HVAC 21 07-25-2010 09:20 PM
run capacitor blew up caught fire in AC unit. saltshaker30 HVAC 2 07-01-2010 10:08 PM
Condenser motor and Capacitor confusion ryanru HVAC 5 06-26-2010 01:25 PM
Would a short circuit in one room cause the A/C capacitor to blow? homerb Electrical 5 05-10-2010 04:34 PM
