A/C Blower Quits Working! - HVAC - DIY Chatroom Home Improvement Forum
Old 06-18-2009, 09:32 AM   #1
A/C blower quits working!
I have been having trouble with my a/c unit. I turned it on last night and everything proceeded to turn on and I had cold air coming out the vents. After about 10 minutes air quit coming form the vents, so I went to check out the unit and the blower was not working. I checked the blower and everything spins freely and is pretty clean. After visually checking everything out I cycled the door switch on the unit and the blower came back on but shut off after about 10 minutes again. Does anyone have any idea what the problem could be or how to help me troubleshoot it?
Jeffrey3156 is offline   Reply With Quote
Old 06-18-2009, 09:47 AM   #2
Experienced goon
Does the compressor come on? When the blower goes off, is there still 24VAC at that thermostat? This season the relay in my compressor shorted, which caused the transformer in the air handler to trip, which shut everything down. My transformer didn't have thermal protection, so it burnt itself out, but yours might be tripping and resetting when you cycle the power. Or it's something totally different.
jpelzer is offline   Reply With Quote
Old 06-18-2009, 10:07 AM   #3
Yes even though the blower stops everything else, ie compressor and the fan is working as it should be. I will have to check the volts at the thermostat.
Old 06-18-2009, 10:21 AM   #4
HVAC / Plumbing
is there any dust ,etc, build up on the motor where it bolts to the blower ?? I have seen dust etc, build up in this area & cause over heating of the motor.. Check the high speed connection at the circuit board
kenmac is offline   Reply With Quote
Old 06-18-2009, 10:34 AM   #5
Yes it was fairly clean to begins with, but I cleaned it thoroughly and the connections are good.
Blower Works Once, then Quits Scottie T HVAC 3 02-05-2009 12:06 PM
Furnace blower not working right. oiljumper HVAC 4 11-10-2008 10:22 PM
Trane xv80 furnace blower not working jim2138 HVAC 2 03-22-2008 04:55 PM
Blower Not Working sursedur HVAC 2 03-02-2008 08:39 PM
RUUD furnace not working blower runs ddeatrick99@hotmail.com HVAC 2 01-16-2008 09:55 PM
