Old 03-31-2010, 03:27 PM   #1
A/C Blower Motor Seems Slow
Greetings to all,
I am a new member and this is my first post.
My a/c blower motor appears to be running at a slower speed than in the
past. I have a 4 speed Dayton direct drive blower model sc093B. It is wired correct for high speed which is the Black and white wire. All other wires are capped off. I did check the run cap. which is 12.5 uf. it tested out at 10.6, so i replaced it. I did check the new one and it is right on at 12.5 uf.
I also ohm cked the Motor windings.
white to black = 2
Black to brown =35
white to brown =37
Blower motor is clean and turns very freely .
I'm not sure if the Ohm test should have different results ?
What else should I be checking and how ?
appreciate any help on this
PillMD is offline   Reply With Quote
Old 03-31-2010, 04:02 PM   #2
An old Tradesmen
White to black ohm is low.
Old 03-31-2010, 08:25 PM   #3
I appreciate your response.
What should the Ohm reading be from white to black ? Is this low reading an indication that the Motor is going and needs to be replaced ?
Phil
Old 03-31-2010, 08:31 PM   #4
An old Tradesmen
Varies with the motor a lot.
But 2 ohms is very low. Indicates a possible shorting of one winding to the other.
Would expect 10 plus.
Motors are inductive loads. So they don't ohm out like resistive loads.
Old 03-31-2010, 08:40 PM   #5
MXer
3 legged dog's Avatar
Also check the vanes on the squirel cage for caked on dust. Ive seen the added weight slow a motor.
2 ohms does seem low for a run winding.
3 legged dog is offline   Reply With Quote
Old 04-01-2010, 09:17 AM   #6
Jack of All Trades...
From the looks of the manual, that motor has oil ports. When was the last time it was oiled? May have something to do with it.
TJ
TJ_in_IL is offline   Reply With Quote
Lennox furnace blower runs slow ventport HVAC 9 02-21-2010 05:42 PM
Blower cycling and vibration whatshappening HVAC 1 02-09-2010 05:48 AM
Trane Furnace Blower Running Nearly Continuously stephensandlin HVAC 3 01-03-2010 02:21 AM
Carrier 58MXA Wiring Blower Switch 63012753 HVAC 0 10-06-2009 10:09 PM
Main blower is very slow on York Diamond 90 dnastrau HVAC 5 08-01-2009 02:11 AM
