-   -   A/C Blower Motor Seems Slow (http://www.diychatroom.com/f17/c-blower-motor-seems-slow-68023/)
PillMD 03-31-2010 02:27 PM
Greetings to all,
I am a new member and this is my first post.
My a/c blower motor appears to be running at a slower speed than in the
past. I have a 4 speed Dayton direct drive blower model sc093B. It is wired correct for high speed which is the Black and white wire. All other wires are capped off. I did check the run cap. which is 12.5 uf. it tested out at 10.6, so i replaced it. I did check the new one and it is right on at 12.5 uf.
I also ohm cked the Motor windings.
white to black = 2
Black to brown =35
white to brown =37
Blower motor is clean and turns very freely .
I'm not sure if the Ohm test should have different results ?
What else should I be checking and how ?
appreciate any help on this
beenthere 03-31-2010 03:02 PM
White to black ohm is low.
PillMD 03-31-2010 07:25 PM
Too Low OHm reading
I appreciate your response.
What should the Ohm reading be from white to black ? Is this low reading an indication that the Motor is going and needs to be replaced ?
Phil
beenthere 03-31-2010 07:31 PM
Varies with the motor a lot.
But 2 ohms is very low. Indicates a possible shorting of one winding to the other.
Would expect 10 plus.
Motors are inductive loads. So they don't ohm out like resistive loads.
3 legged dog 03-31-2010 07:40 PM
Also check the vanes on the squirel cage for caked on dust. Ive seen the added weight slow a motor.
2 ohms does seem low for a run winding.
TJ_in_IL 04-01-2010 08:17 AM
From the looks of the manual, that motor has oil ports. When was the last time it was oiled? May have something to do with it.
TJ
