A/C Behavior During Power Hits - HVAC - DIY Chatroom Home Improvement Forum
Old 07-01-2012, 12:41 PM   #1
Rewards Points: 20
A/C behavior during power hits
We had that wonderful east coast monster line of storms blow through our area Friday night. We're very fortunate to have power and no damage.
Our Amana A/C unit is one year old. We had several quick power hits during the storm front, during which the air conditioner was running. I noticed that, even though the blower and the outside unit fan were both running, there was no cool air coming out of our ducts. However, about 20-30 minutes later, the system started cooling again, and has worked fine ever since.
Is there some sort of compressor safety circuit that shuts it off if there are power hits like that? Just curious....
steveKane is offline   Reply With Quote
Old 07-01-2012, 01:28 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
if the compressor had short cycled it may have not started and tripped the internal overload. After it reset it may be fine now.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 07-01-2012, 01:48 PM   #3
Retired from the grind
gregzoll's Avatar
Rewards Points: 6,638
I ended up placing a timer controller on the lv side of my A/c unit outside, and set for about 30-45 sec's, so if it is a immediate trip, the unit will not start up right away.
Ren: Now listen, Cadet. I've got a job for you. See this button? Ren: Don't touch it! It's the History Eraser button, you fool! Stimpy: So what'll happen? Ren: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
gregzoll is online now   Reply With Quote
How does grounding work? scyarch Electrical 44 06-12-2012 04:59 PM
Power strip hack salex Electrical 3 01-31-2012 06:10 AM
Recurring Power Oddities - Regular Schedule DamienChaos Electrical 16 10-21-2009 07:45 PM
safe way to add extension to power cord sil Electrical 7 10-18-2007 09:58 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 10:23 PM
