A/C Always On With Fan Switch "on". - HVAC - DIY Chatroom Home Improvement Forum
Old 07-25-2010, 10:16 AM   #1
Rewards Points: 77
A/C always on with fan switch "on".
Why does the a/c run non-stop when the thermostat fan switch is set to on?
We just moved in with friends and to get some air flow we switched the fan control from "auto" to "on", we left for a few hours and when we came back it was 58 degrees in the house.
I verified the Honeywell thermostat wires were coordinated with the wires on the "R","W","Y" and "G" on the circuit board of the furnace. and the "C" and "Y" go to the a/c compressor. So I thought it might be the thermostat, so I switched it with another and it also turns on the a/c compressor when the fan switch is turned on, even when the "heat off cool" switch is "off". What is going on?
bkvanbek is offline   Reply With Quote
Old 07-25-2010, 10:32 AM   #2
Likely a short between the G and Y wire in the wall. Cheap meter will let you know for sure.
Old 07-25-2010, 10:35 AM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 2,230
Where do you live? In Canada we have new homes with a central exhaust system. The system is interlocked to the furnace. You can get a backfeed to the AC from G if it is not wired correctly. Happens to electric furnaces also. Post the make and model # of the furnace.
fan/light switch buzzing mjlocat Electrical 4 05-23-2010 02:44 PM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
