A/C Air Handler & Condenser Both Won't Turn On - HVAC - DIY Chatroom Home Improvement Forum
Old 04-26-2013, 10:38 PM   #1
Hey everyone. I'm new to the forum and hoping to find some help!
I was cutting the yard this evening and noticed that my dog had chewed through some of the wiring that connects the outdoor A/C condenser to the t-stat. I tested the system inside and the air handler would turn on but the condenser would not. While the system was running, i touched two of the light-gauge wires together and the condenser turned on just fine.
I then cut the power to the system at my breaker inside the house and repaired the wiring outside. I turned the breaker back on and now no components of the system will turn on. I've tried to reset the breakers and the light switching looking thing by the handler several time, all with the t-stat off. I don't see any other reset buttons that should be pushed but I could be missing something. I do hear the t-stat clicking on any off but the system would come on.
Any thoughts on what might be going on??
Thanks very much!
SHarr5184 is offline   Reply With Quote
Old 04-26-2013, 10:54 PM   #2
Control board fuse blown? had a t-stat wire short and kept poping the 3A fuse every time the condenser tryed to run but then again when it poped the fuse the t-stat went blank/dead. Never found the actual short in the wire but changed out the old brittle wire with new stuff, worked fine since.
Exjay is offline   Reply With Quote
Old 04-26-2013, 11:09 PM   #3
I hadn't thought to check for a fuse there but, if there is one, that could well be it since I messed with the damaged wires while the system was on. Ill check that in the morning. Thanks!
Old 04-28-2013, 07:27 AM   #4
biggles's Avatar
before repowering remove the stat off the subbase and verify 24Vs at the furnace.air handler TR...if the fuse blows right off..remove the 2 low vltage wires into the condenser could be the contactor coil or the run out from the air handler
Old 04-28-2013, 09:39 AM   #5
I found a blown 3amp fuse on a control panel inside the air handler that was causing the issues. It replaced it last night and we're back up an running. Thanks for your help!
Old 04-28-2013, 08:42 PM   #6
Nice!
24v not present at terminal block or tstat wire leading to condenser outside? Vonderbach HVAC 16 01-17-2013 12:57 AM
York condenser unit not kicking on via thermostat, but works fine with override. Vonderbach HVAC 1 01-13-2013 05:31 PM
Goodman air handler will not start normally jomamba HVAC 3 07-19-2011 09:03 PM
Proper way to clean the air handler drain lines lithium1330 HVAC 2 11-25-2008 10:48 AM
Replacing air handler - How to fit when form factors are slightly different?? hennyh HVAC 2 11-16-2006 09:23 AM
