A/c - HVAC - DIY Chatroom Home Improvement Forum
Old 06-23-2009, 06:34 AM   #1
Cyd
A/c
hi there! i had a new furnace installed in nov. 08 and now that i need my A/C it is not working.....and before you ask yes i have the power on will i am pretty sure it is...can anyone maybe suggest what i might look for to find the problem????? please!!!!
Cyd is offline   Reply With Quote
Old 06-23-2009, 06:37 AM   #2
sktn77a's Avatar
Rewards Points: 392
HAs it ever worked, since it was installed?
sktn77a is offline   Reply With Quote
Old 06-23-2009, 06:40 AM   #3
Cyd
a/c
no! and i dont think anyone tested it since we had 3 ft of snow at the time
Old 06-23-2009, 07:45 AM   #4
Home Air Direct's Avatar
This one is easy. Call the last guy who had it disconnected
If your contractor disconnected your AC to replace your furnace, and there was snow on the ground, they could not have completed the start-up of the full system, just the heating.
I am unclear on one part of your situation. Did you only have the furnace replaced? Or, did you have the whole system replaced including the AC and the evaporator coil that is attached to your furnace.
Good Luck
Settle down! If you were that important, the city would give you lights and a siren for your car
Home Air Direct is offline   Reply With Quote
Old 06-23-2009, 08:00 AM   #5
Check the outside fuse box for the ac.
hvaclover is offline   Reply With Quote
Old 06-23-2009, 08:06 AM   #6
I was giving credit for that one with the "I am pretty sure I have the power on" in the OP. I guess I was ASSuming
Last night my niece called me and said that their AC was out. She lives up the block, so I went to look. I said "go outside and kill the power to the unit". She came back in and said it was done, but I heard a click that indicated otherwise. I went out and she had unplugged her Rainbird sprinkler system Ended up being a simple run cap. Now I am a hero.
Old 06-23-2009, 10:39 AM   #7
Im' thinking the disconnect pull out being turned around to "off".
We do that with winter installs to make sure the ac does not come on 'til we go back and do the spring check out.
