Bypassing Fan Circuit Board - HVAC - DIY Chatroom Home Improvement Forum
Old 12-16-2009, 04:36 PM   #1
Bypassing fan circuit board
I have a Bryant heat pump with a bad blower circuit board. There is a loose connection in it and the blower doesn't come on when it should. I have ordered a new board. While waiting for the new board to arrive, is it OK to jump the fan relay leads to run the fan constantly? Thanks.
javahutbum is offline   Reply With Quote
Old 12-16-2009, 06:00 PM   #2
An old Tradesmen
Rewards Points: 7,372
You can(its ok, no harm done if ran 24/7) bypass the relay till the new board comes in.
Tags
bryant , circuit board , heat pump
installing backer board over particle board bob mac Flooring 6 07-16-2013 03:15 PM
Carrier furnace control board - OEM or ICM ? anku HVAC 13 10-12-2012 10:50 PM
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 03:34 PM
luxaire/york 33109167000 furnace board replacement check HVAC 18 07-13-2009 10:03 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
