Bypass Humidifier Question - HVAC - DIY Chatroom Home Improvement Forum
Old 12-13-2012, 04:46 PM   #1
Rewards Points: 129
bypass humidifier question
I'm in the process of getting a bypass humidifier installed on my infinity furnace.
I understand that the water supply could either be tapped into either hot or cold.
What are the advantages/disadvantages of each?
jeepgrady is online now   Reply With Quote
Old 12-13-2012, 06:07 PM   #2
HVAC Tech/Owner
Rewards Points: 604
Hot Water
Technow is offline   Reply With Quote
Old 12-13-2012, 06:21 PM   #3
Experienced HVAC Tech
HVAC1000's Avatar
Hot water will evaporate a lot faster and get into the air better and more efficiently
HVAC1000 is offline   Reply With Quote
Old 12-13-2012, 06:40 PM   #4
HVAC Tech/Owner
Rewards Points: 604
Old 12-13-2012, 06:42 PM   #5
Rewards Points: 484
Make sure if you use hot water, that you dont tap into a large line if it's too far from the water heater. I just installed one in my house a couple weeks back and they use so little water, that the line never got hot.
I ended up having to run a dedicated 1/4 inch line directly to the water heater, about 25 feet.
sammy37 is offline   Reply With Quote
Old 12-13-2012, 07:31 PM   #6
Rewards Points: 582
we like hot water..ben sr...try not to use a saddle valve they are junk..
Honeywell TrueSteam Humidifier Opinions/Experience dgbehrends HVAC 239 01-16-2012 03:08 PM
Goodman GMP100-3 Humidifier Issue olds2000 HVAC 1 11-20-2010 10:18 PM
HVAC Humidifier Question rubicon789 HVAC 8 01-13-2009 11:06 AM
New humidifier install question wlee69 HVAC 1 09-24-2008 11:52 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
