-   -   bypass humidifier question (http://www.diychatroom.com/f17/bypass-humidifier-question-166387/)
jeepgrady 12-13-2012 04:46 PM
I'm in the process of getting a bypass humidifier installed on my infinity furnace.
I understand that the water supply could either be tapped into either hot or cold.
What are the advantages/disadvantages of each?
Technow 12-13-2012 06:07 PM
Hot Water
HVAC1000 12-13-2012 06:21 PM
Hot water will evaporate a lot faster and get into the air better and more efficiently
Technow 12-13-2012 06:40 PM
sammy37 12-13-2012 06:42 PM
Make sure if you use hot water, that you dont tap into a large line if it's too far from the water heater. I just installed one in my house a couple weeks back and they use so little water, that the line never got hot.
I ended up having to run a dedicated 1/4 inch line directly to the water heater, about 25 feet.
ben's plumbing 12-13-2012 07:31 PM
we like hot water..ben sr...try not to use a saddle valve they are junk..
