Old 10-07-2012, 10:47 PM   #1
Bypass Blower Time Delay Relay?
I am installing a heat pump split system and are not getting 24v at the BTDR. I beleave i can bypass BTDR with out damage. I just want another opinion.
timtimory is offline   Reply With Quote
Old 10-07-2012, 11:23 PM   #2
schematic please..... or go ahead and duck....lol
carmon is offline   Reply With Quote
Old 10-07-2012, 11:49 PM   #3
I am installing a heat pump split system and are not getting 24v at the BTDR. I beleave i can bypass BTDR with out damage. I just want another opinion. The schematics show from the transformer to the Blower Time Delay Relay and dose not show normaly open or closed and from the relay out of the airhandler case.
Old 10-08-2012, 09:52 AM   #4
Thermostat, outside, and airhandler units red wire are not getting 24 volt. these are tapped at air handler. red wire going into blower time delay relay board not getting 24v. red wire comes out to the transformer reads 24v. this wiring is how the schematic shows. I got to get this system running. Im gonna bypass board temporaly.
Old 10-08-2012, 06:02 PM   #5
An old Tradesmen
Might have a blown fuse. If so, you got a short somewhere.
The Following User Says Thank You to beenthere For This Useful Post:
timtimory (10-09-2012)
Old 10-09-2012, 08:33 AM   #6
What is XFMR-R and XFMR-C on the wire diagram. XFMR-R is the pin that has no 24V coming through.
Old 10-09-2012, 03:12 PM   #7
An old Tradesmen
R is the 24 volt hot, C is the 24 volt common.
Old 10-12-2012, 11:13 PM   #8
The 3 amp fuse at the relay board was found to be blown after i bypassed the relay. bypass worked the blower came on. I jumped 24v red to fan green. I did the same with the heat coil. the both work. I changed the fuse and put the themastat back up. Its not turning anything on. I then took it off and lost power again. I guess the fuse is blown again. It looks like a faulty thermastat. I know the R is for 24v and C is for common. What is XFMR stand for?
Old 10-13-2012, 09:06 AM   #9
An old Tradesmen
Transformer.
ben's plumbing (10-13-2012)
Old 10-15-2012, 03:36 PM   #10
I tryed a different thermastat and the fuse still blew. I checked over the wires and all conections are tight. I tested the primary and secondary power on the transformer. Fuse only blows when thermastats are hooked up. It dosen't when i jump 24v power. it worls fine when power is jumped. is there a known proble with Goodman Heat pump units and air handlers?
Old 10-15-2012, 05:01 PM   #11
Sounds like the thermostat isn't wired right.
The Following User Says Thank You to Marty S. For This Useful Post:
timtimory (10-15-2012)
Old 10-15-2012, 05:25 PM   #12
An old Tradesmen
Thermostats? You have more then one thermostat connected to it?
List what wires are connected where. As above, sounds like its a wiring problem.
Goodman doesn't have a problem with their units shorting out.
Old 10-15-2012, 09:55 PM   #13
I got it working. I miss placed one wire after all. The common was on RC instead of C and jumper from R to Rc.
Old 10-15-2012, 09:57 PM   #14
Three fuses latter I learned a lesson on first Heatpump install by my self.
Odd Fireplace Outlet Behavior permagrin Electrical 2 12-17-2011 09:06 AM
Comfortmaker blower intermittent problem jh44ny HVAC 12 07-31-2011 07:41 PM
Aprilaire part 4851 Blower Activation Relay glassr HVAC 0 09-25-2009 04:57 PM
2 Stage AC with older Furnace? SteveTheBuilder HVAC 5 07-18-2008 09:04 PM
Furnace's blower is on all the time but gas burner does not start artgue HVAC 3 01-16-2008 06:46 PM
