02-17-2013, 11:12 AM
#1
buying parts online ?
i want to get a few spare parts for my furnace, so i have them on hard should/when a break down occur. i have a TAPPAN furnace, says NORDYNE on the inside sticker. when i was looking up parts, i found a place that listed my nordyne parts. it had only 1 listing for each part. does this seem right for this brand ?
also, is there a good place to get parts online ? one to stay away from ?
thanx.
btw, i am looking for a start/run capp. and a hsi.
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
02-17-2013, 11:15 AM
#2
02-17-2013, 11:35 AM
#3
An old Tradesmen
Run caps can be gotten from a lot of different sites. oesn't have to be listed for a Nordyne. Just need to match the uF rating and be the same voltage or higher voltage. HSI can be generic also.
02-17-2013, 11:50 AM
#4
i was thinking the same thing.
what about chinese parts ? these days, bout everything is made there.
02-17-2013, 11:57 AM
#5
An old Tradesmen
I try to stay a way from them.
02-17-2013, 12:00 PM
#6
yeah, but how do i know ? i doubt that they will state thats it made in china.
02-17-2013, 12:43 PM
#7
An old Tradesmen
That I can't say, I buy my parts at HVAC supply houses where I can see where it came from.
You can always go to Graingers.
02-17-2013, 03:44 PM
#8
Roofmaster
www.pexsupply.com First Rate, Decent Prices
" A lot of men build things, and a lot of things fall down "
02-17-2013, 04:10 PM
#9
MarginallyQualified
Originally Posted by Fix'n it
yeah, but how do i know?
You don't know.
Don't for a second believe that Tappan (or Trane or Rheem or Lennox or any other other appliance makers) actually make the parts touted as being "OEM".
It's not that the characteristics of a given control or component part aren't different between the ones used by Tappan or Trane or Rheem or Lennox or any of the other other appliance makers... they are.
The issue is that the differences should be inconsequential.
They only matter because Tappan or Trane or Rheem or Lennox has designed their OTHER outsourced components to NOT work (or not work as well) with one of the other very very similar control or component part that they could have used instead.
02-17-2013, 05:39 PM
#10
registered
My first stop is always amazon.com They always come through 9 times out of 10
02-17-2013, 08:12 PM
#11
Originally Posted by TarheelTerp
You don't know.
yeah, i understand that. the same factory shoots out the same part for all of them. just a different # and perhaps shape. but i don't want to take a chance.
i will just get those parts i linked. install them, to be sure they work. and just leave em in there. then i have the removed parts for a backup, that i may never need.
02-17-2013, 11:13 PM
#12
HVAC Parts Outlet ...and this one.
Do you want it your way or the right way? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
02-18-2013, 08:48 PM
#13
Originally Posted by Missouri Bound
your late to the party. thats the same place i linked.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
