Bury Gas Line Tips - HVAC - DIY Chatroom Home Improvement Forum
Old 03-25-2010, 11:26 AM   #1
Bury Gas Line Tips
Hi,
I'm burying a natural gas line from meter to the garage. Looking for some tips. I have had 60' 1/2 (ID) copper running on the ground all winter now want to bury that. The trench is not a straight shot to the garage so copper seems to be the best option.
My plan is to use black pipe from meter down 3' with 90 elbow. There connect the gas line with flare fitting. Same thing on the outside the garage wall, black pipe from 3' down up and into the garage.
Looking for tips. Seems copper line underground is find but not sure about the fittings underground like that. Wondering if I should wrap the area where the fittings are in some type of tape?
Thanks,
Dustin
RoundPorch is offline   Reply With Quote
Old 03-25-2010, 11:55 AM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 142
Check code. Here it is against code for copper line to be in contact with dirt.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 03-25-2010, 01:23 PM   #3
the Musigician
DangerMouse's Avatar
You don't mention your location, so I assume you likely live somewhere a permit will be required to do this work, IF you can even DIY!
So, if this is true, then your best bet is always to ask the inspectors. Their job is to keep us safe by making sure our work is at or above par. Better safe than "tear it out and do it again!"
DM
Old 03-25-2010, 01:35 PM   #4
DM
I'm in MN, Wright County. We have an inspector in town hall. I'll ask the him, I'm 99% sure he'll want a permit. Be fun asking him after I've done all the work , everything except bury he line.
Old 03-25-2010, 01:42 PM   #5
the Musigician
Yup, you sure will, and it's a good thing too! Keep your family safe, my friend, and good luck!
Feel free to ask again any time here if you get stuck.
DM
Old 03-25-2010, 03:25 PM   #6
Originally Posted by RoundPorch View Post
...My plan is to use black pipe from meter down 3' with 90 elbow. There connect the gas line with flare fitting...
I seem to recall from a recent review of my "Code Check" sheets that gas line flare fittings can not be concealed. Now I'm sure the main point of the line I saw was to make sure you don't bury flare fittings behind drywall... but I would think that would also proclude a flare fitting underground... unless you had some sort of an accessable pit.
HooKooDooKu is offline   Reply With Quote
New pool house with new toilet - tips wanted kandrewp Plumbing 3 07-28-2010 08:47 AM
Natural gas line????? figs Plumbing 1 06-14-2009 01:13 PM
Add natural gas line Tukeeman Plumbing 11 12-01-2008 07:53 AM
electric line and gas line couch potatoe Electrical 17 09-30-2008 10:43 PM
Condensate Line schott HVAC 17 06-02-2008 03:16 PM
