Burnham V-7 Furnace Leaking Water - HVAC - DIY Chatroom Home Improvement Forum
Old 11-25-2008, 11:59 AM   #1
Burnham V-7 furnace leaking water
I have a 1997 Burnham V-7 furnace Model number PV73WBT. Upon removal of the side panels, there is a crack in the first cast iron plate which is leaking water.
Can just the 1 plate be replaced, or does the whole unit need to be replaced?
Fastlane is offline   Reply With Quote
Old 11-25-2008, 06:48 PM   #2
An old Tradesmen
Rewards Points: 7,332
Burnham generally sends a whole new block.
And it takes less tiem to change out an entire block, then just a section.
Old 11-26-2008, 10:43 AM   #3
Is it worth changing out the block or purchasing a new boiler? Would the new block be more reliable than the old one or do they still have the same problem?
Old 11-26-2008, 04:33 PM   #4
An old Tradesmen
They don't give you another V7 block. It'll be a V*, which is made heavier then the V7 was.
If you can wrangle a MPO from them, it would be a better boiler.
Old 11-28-2008, 02:20 PM   #5
tk03's Avatar
Rewards Points: 150
He is past the 10 year warranty and now in the proration warranty if he is the original owner. He will get a new V7 block unless it is a steam boiler than a V8. He can swing a deal on a new V8 or MPO if a water boiler.
tk03 is offline   Reply With Quote
Old 11-28-2008, 06:46 PM   #6
Not the orginal purchaser, which means i get the short end of the deal. It's a water boiler so, am i better off getting a new boiler or putting in a new block?
If i go new, do i stick with Burnham v-8, MPO or go with another mfg?
Old 11-29-2008, 03:35 AM   #7
An old Tradesmen
I'd go with an MPO instead of the V* if you stick with Burnham.
Old 11-29-2008, 07:34 AM   #8
tk03's Avatar
Rewards Points: 150
As always I agree with Beenthere. The MPO is a three pass boiler which runs about 87%. The MPO follows the European lines but I am told is easier to service. It does not come with a domestic coil as no boiler should. The most important thing is proper sizing. Do a heat loss before getting quotes and that way everyone is on the same page.
For more info on heat loss see this link.
www.comfort-calc.net
Help My Admiral Refrigerator is leaking water Cuwillis Appliances 10 03-25-2014 08:21 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
Furnace troubles, where's the water coming from... Head Scratcher HVAC 10 03-23-2008 07:40 PM
leaking water main LanterDan Plumbing 4 08-31-2006 07:24 AM
