Old 12-09-2008, 05:04 PM   #1
Old Burnham Series 2
Question Burnham Series 2 Cast Iron Radiator System
I have a Burnham Series 2 boiler with 5 cast iron radiators attached and one circulator for the whole system. It is a closed system. It has a B-38 PRV as the only way I can see to get water into the system from the street. (Same water pipe connected to water heater with a spichot valve in between.) The boiler is in the basement, 4 radiators are on the 1st floor, the 5th is on the second floor.
How do I fill this system up with water in this configuration? It is a early 1900s house with a late '89 early '90s boiler. I cannot tell if water is getting into the system through the PRV. Also the system has a single expansion tank mounted in the basement rafters above the boiler. It is an older tank and always empty. Never felt water in it, warm or cold.
Any suggestions or methods to get water into the system, the system bled and the expansion tank working would be greatly appreciated.
SybrSave
SybrDave is offline   Reply With Quote
More On This Topic
On behalf of Expert Village my name is Tom Roland and we're at Cottonwood Motor Sports and I'm here to tell you about doing service on a Polaris Quad and this is fairly representative of many of them. The radiator on a Polaris on the units with a box on... Read More »
Anyone living with large, steaming hot radiators in their home will eventually think of replacing them with something smaller and cooler. A simple solution is to replace your radiator with a smaller, less sizable convector. Here are the steps to replace... Read More »
Hi I'm Doug. I work with twenty great guys in St. Louis at Doug Jenkins Custom Hot Rods, and we're going to do some work for you today on Expert Village. Now we're going to install radiator hoses. What we got going there is the thermostat housing on the... Read More »
On behalf of Expert Village, my name is Tom Roland and we are here at Cottonwood Motor Sports and we are here to tell you about doing service on a Polaris Quad and this is fairly representative of macho, many of them. This is the expansion tank for the... Read More »
Most people think about their water heater only when it fails. It's one of those things you couldn't live without, but as long as it does its job, you ignore it. And when it breaks down, you have no idea what to do. You can replace that old water heater... Read More »
working with cast iron ericadami Plumbing 9 11-30-2008 02:45 PM
How are cast iron drains? Do you have to plunger them often? twilightcall Plumbing 4 08-29-2008 02:07 AM
Cast iron and rusty pipe question snowens Plumbing 2 07-27-2008 12:07 PM
smoothening cut cast iron pipe before mounting fernco coupling amakarevic Plumbing 6 11-15-2007 07:39 PM
Help with Cast Iron Material Tester Plumbing 2 10-25-2007 12:58 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
