Old 07-05-2011, 05:00 PM   #1
Burnham oil burner
How do I bleed the line to restart burner
Don Gregory is offline   Reply With Quote
Old 07-05-2011, 06:18 PM   #2
An old Tradesmen
Burnham oil burner
1/8" ID hose, 3/8" wrench.
connect hose to bleeder port, open port with 3/8" wrench, push reset button. Close when oil comes out in a steady stream. may take more then one push of reset button. make sure bleeder is open pretty far so pump does not pump oil into burner while your bleeding it. makes for a nasty light off, that can fill your house with smoke, and bring out the fire department.
monitor heater repair help speakers3 HVAC 13 11-25-2012 10:44 PM
Older Carrier Pilot Burner Problem cliffkot HVAC 23 04-29-2011 06:58 PM
Burnham V7 Series oil burner Barrywilly Appliances 0 11-01-2010 10:46 AM
Broken Burner Fix mikelbeck HVAC 2 01-16-2009 10:05 PM
Question about gas burner design darsunt HVAC 4 12-14-2008 02:37 PM
