Burnham KV84 Oil Furnace Dead This Morning - HVAC - DIY Chatroom Home Improvement Forum
Old 02-22-2012, 09:54 PM   #1
My friend has a Burnham KV84 oil burner.
I have checked the breaker and boiler switch the thermostat is all the way up tank is almost full
But it shows no sign of life at all.
The burner unit 2 reset buttons one up front near the head, and the other on the right towards the rear, it would appear to be the electrical portion.
It has a reset button and a green LED. The LED is off and remains off despite the reset button. I can't read what it says since it's mounted inches from the wall.
I'm more familiar with electric and basic gas systems. Not sure where to go with this, any tips on what else I should look at?
The water level isn't marked like I've seen generally so I was reluctant about letting any in. It was somewhere between 1/4 and 1/3 cold.
Kenny
kenny782 is offline   Reply With Quote
Old 02-23-2012, 04:39 AM   #2
An old Tradesmen
Rewards Points: 8,234
Does it have power.
Old 02-23-2012, 09:01 PM   #3
REP
You don't give us a lot to work on.
Did you check the manual reset high limit?Do you have a low water cut off?Could be a bunch of things.
REP is offline   Reply With Quote
Furnace Won't Start In The Morning chiimpy HVAC 13 02-25-2011 10:04 PM
dead mice in furnace TerPer HVAC 8 01-16-2011 07:26 PM
tiling under new furnace gramps416 Flooring 4 01-09-2011 10:47 AM
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 05:01 PM
