Burnham Furnace Short Cycling - HVAC - DIY Chatroom Home Improvement Forum
Old 02-07-2008, 11:37 AM   #1
Burnham furnace short cycling
have a 20+ year old Burnham hot water boiler that short cycles when maintaining boiler temp for domestic hot water - cleaned boiler, replace aquastat - reset hi low dif settings runs 30 sec off for 4 min
ademaggi is offline   Reply With Quote
Old 02-13-2008, 03:36 PM   #2
Did you check your water level??...water feed to boiler must be on all the time...some high end units like yours have a low water cut off to protect the unit..some reset themselves...water temp gauge in front has temp on top and pressure on bottom...I like between 10 / 15lbs....also you might have an air bleed on top of boiler
econoline is offline   Reply With Quote
Old 02-13-2008, 03:51 PM   #3
Burnham furnace - short cycles
I have not checked the water level or but am sure the feed valve is open - did not check if the system is air bound - will verift that too - system runs between 10 & 20 lbs
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 07:01 PM
Problem with Burnham Oil Furnace short cycling Catherine M Brown HVAC 13 01-29-2009 10:58 AM
furnace cycling / shut down Snailspace HVAC 12 02-04-2008 09:08 PM
oil furnace problem Dave80 HVAC 1 01-24-2008 07:53 AM
Replacing My Furnace, few simple questions compression HVAC 10 02-03-2007 05:00 PM
