Old 01-16-2012, 08:13 AM   #1
Burnham furnace knocking
I have a burnham gas furnace wth forced hot water baseboard. I have recently noticed that the boiler makes a knocking sound when it is on. What could the problem be. Plumber looked at furnace and it shuts down at 180 and no air in lines.
eam16 is offline   Reply With Quote
Old 01-16-2012, 11:46 AM   #2
Master General ReEngineer
Bondo's Avatar
Ayuh,.... You have a Boiler, not a furnace....
While I'm not a HVAC Pro,...
I'd guess there's a build up of crud in the base of the boiler(inside the water jacket, above the firebox)...
That'll cause a hot spot, 'n the knockin' is a result of it....
Old 01-16-2012, 12:04 PM   #3
how
What's the press & temp on the tridicater on the boiler read?
The first thing to check...Expansion tank.
Tap the side of the expansion tank. I/2 should sound solid (filled with water) and 1/2 should sound hollow (filled with air). If it all sounds solid then it's time to change it as the internal bladder has ruptured.
Does your relief vent water during a heating cycle?
Do you hear water running in the baseboards or heating lines?
how is offline   Reply With Quote
Propane Furnace - Diminishing Gas Supply After Ignition edro HVAC 9 01-13-2012 05:24 PM
Help! with Concord 80+ gas furnace + T-STAT joryeln HVAC 0 09-16-2009 01:23 PM
Oil furnace / tank questions... pure_energy1 HVAC 26 06-22-2009 09:47 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
Burnham V-7 furnace leaking water Fastlane HVAC 7 11-29-2008 08:34 AM
