Burnham Boiler - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-21-2007, 07:45 PM   #16
ok guys i am back I am going with burnham pvg5 for the boiler. Can you guys recommond an indirect. I don't want triangle tube or well mcclain because i want something with a drain at the bottom of tank so i can flush water out every so often. What do you guys think of the burnham alliance it looks good with hydrostone lining and removable heat exchanger? i am between the burnham alliance, Superstor Ultra, Bock Indirect what should i go with?
The last thing i am concerned with is the pvg noisy. Is the vent fan reliable? I've read online that powerventers are very loud is this true? I am venting out the wall so are there any downsides to doing this? could this discolor my house i have painted cedar siding.
Rschrei518 is offline   Reply With Quote
Old 12-22-2007, 08:04 PM   #17
Union HVAC Tech.
Go for the better boiler and you will be better off in the long run. Igniters don't go bad all the time.
bigMikeB is offline   Reply With Quote
Boiler Options -Will Boiler be good enough??!! deano54321 Plumbing 2 10-28-2007 06:18 PM
Home oil boiler furnace jmb HVAC 5 03-28-2007 07:03 AM
Steam boiler corrosion problem franklopes HVAC 4 11-09-2006 08:02 PM
Whine from a boiler pump? formarley HVAC 2 09-26-2006 07:56 PM
