Burners Won't All Light - HVAC - DIY Chatroom Home Improvement Forum
Old 12-27-2011, 11:59 AM   #1
Burners won't all light
I have a propane furnace that has three burners,about 50% of the time two of the burners will light and the third one won't.I have made sure that the burners are clean and the the orfice is all so clean.some times I can blow a puff of air with my windy mouth and the third will light. I know that the burners have a small channnel that I believe is to carry the flame from the adjacent burners .I have even moved the burners to different locations, no help and the best I can tell the burners are alll the same.What am I overlooking? Vern
Vern Clanton is offline   Reply With Quote
Old 12-27-2011, 12:41 PM   #2
what is your manifold pressure?
harleyrider is offline   Reply With Quote
The Following User Says Thank You to harleyrider For This Useful Post:
plummen (12-28-2011)
Old 12-27-2011, 01:00 PM   #3
how
Rewards Points: 1,104
If you've removed the burners and cleaned them inside and out, ( a piece of very thin metal from a tin can should be able to be slid the same depth into all the crossovers). The crossovers all line up exactly on the same plane and depth.
Is it just one orifice location that is causing problems even when you switch the burners around? When the problem burner does light does it look the same size as the other burner flames? Is it only the burner that is farthest from the gas coming in?
I have never proffessionally experienced this myself but some other techs have talked about baby spiders crawling into the orifices and having webs or dead spiders rolling around inside the gas manifold that randomly limit the ability of an orifice to work properly even when they look clean.
how is offline   Reply With Quote
Old 12-27-2011, 01:22 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Exactly...cob-webs can foul a burner in a matter of hours even if they have been cleaned thoroughly. Check that out first. It doesn't take but a spec of something to foul an orifice or a burner tube and interupt the flow.
XXX
Old 12-27-2011, 06:04 PM   #5
It is the farthest burner from the gas coming in.and when it does finaly light it burns just the same as the other two no differenct in flame and i have checked the one that is causing the trouble and the orfice two times for blockage and there are no spider webs or any other type of bug in them.it just seem to me to be a flame transfer problem that i can not figer out why. Vern
Old 12-27-2011, 06:09 PM   #6
Old 12-28-2011, 05:03 AM   #7
jkv
what you are missing is the ? Harleyrider keeps asking....what is the manifold pressure
jkv is offline   Reply With Quote
Old 12-28-2011, 06:11 AM   #8
Rewards Points: 1,216
Spiders love propane. OH!! What's your manifold pressure? LOL
COLDIRON is offline   Reply With Quote
Old 12-28-2011, 03:16 PM   #9
Hvac Pro
yuri's Avatar
Rewards Points: 1,856
Here's your culprit. I have heard of people huffing freon fumes but apparently these guys like Propane.
Old 12-28-2011, 04:38 PM   #10
jkv
Good one Yuri, LMAO.
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 10:40 AM
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 04:28 PM
Adding 2 more lights to existing light BCH_COLIN Electrical 7 01-24-2011 11:04 AM
Marmoleum repairs muggyfrost Flooring 8 10-16-2008 08:19 PM
