Burners Go Out After 9 Sec. - HVAC - DIY Chatroom Home Improvement Forum
Old 10-14-2009, 08:52 PM   #1
burners go out after 9 sec.
i am working on a ruud model ugdg burners come on for 9 sec. and then go out. i have jumped out the 4 safeties, and replaced the flame sensor. still when the burner ignites it does not light the flame light on the board, then the burners go out. the board works on another ruud unit but it does not match exactly the one that was on this unit. i have replaced the t-stat as well because it would not call for heat.
gdavis.4 is offline   Reply With Quote
Old 10-14-2009, 09:20 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
Try the correct control board
If you have the pressure switch jumped then you must remove the jumper on each start up and after the inducer is running rejumper. The control board needs to see that the pressure switch opens and closes
That is all I have until you get the correct board
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Dayton Gas Furnace burners wont stay lit Marie1313 HVAC 38 10-08-2009 04:38 PM
Burners go out erniemit HVAC 10 03-15-2009 08:09 PM
Burners quit during heat cycle kaw11 HVAC 4 01-24-2009 03:29 PM
Burners won't turn off. Please help. cappy11078 HVAC 3 01-13-2009 08:32 PM
Furnace burners flame out after a few seconds snurb HVAC 3 01-13-2009 07:58 AM
