Burners - HVAC - DIY Chatroom Home Improvement Forum
Old 12-11-2008, 03:35 PM   #1
burners
i have a comfortmaker rpj2 that was install in 1994 i notice that the flames on the bruners seem to be alitte more orange lately is that a problem ? the funace is working fine by the way
rookie134 is offline   Reply With Quote
Old 12-11-2008, 03:56 PM   #2
It's not burning correctly because the flames should be blue. Do you have enough fresh air? Do you have a carbon monoxide detector close to the furnace?
MrControls is offline   Reply With Quote
Old 12-11-2008, 04:10 PM   #3
burners
i have one at the top of my stairs i live n a town house it has a open loaf area the furnace is right down stairs, we do keep the door to the room where the furnace is crack alittle
Old 12-11-2008, 04:40 PM   #4
Sounds like you have enough air and the co sensor is definitely good.
Someone with more experience will have to help you. Good luck
Old 12-11-2008, 05:17 PM   #5
Orange flame is ok as long as it is not blowing back. The orange is generally dust being burned by the flame. A yellow flame, however, is not good as this indicates incomplete combustion and a problem with the furnace.
SKIP4661 is offline   Reply With Quote
Old 12-11-2008, 07:26 PM   #6
Hvac Pro
yuri's Avatar
Rewards Points: 2,240
Those can be VERY dangerous furnaces. Just condemned a 1993 NUG/one today. They have had LOTS of cracked heat exchangers/popped compression rings which hold the exchanger together. It will eventually trip the flame rollout switch in front of the burners. Best to get it checked by an experienced pro. Have him put a stick type thermometer by the rollout switch. After the fan cuts in the temp will rise over 100 degF to up to 300 degF and eventually trip that switch as the fan is forcing air thru the crack into the burner area and pushing the flame out the front. May take 5 minutes of running B4 the crack opens enough for this to happen. If it stays under 100 deg F it is Okay. Best to be safe than sorry.
Lennox furnace problem devgill08 HVAC 5 12-11-2008 07:38 PM
pilot lights, but not burners DangerMouse HVAC 34 09-14-2008 07:19 AM
Paint under stove burners? dsgs Painting 5 12-09-2007 04:48 PM
Turning down furnace burners? Squire HVAC 3 11-17-2007 08:53 PM
Whirlpool Furnace - Burners cycle every 10 to 20 Seconds agtsrbt HVAC 3 02-06-2007 04:39 PM
