Burner Wont Stay Lit - HVAC - DIY Chatroom Home Improvement Forum
Old 12-08-2010, 08:53 AM   #1
burner wont stay lit
50,000 btu rudd furnace with hot surface igniter the inducer fan comes on and the igniter lites and when the flame comes on and the igniter goes out the flame goes out as well i have checked all wire connections and replace igniter and still no luck i cant find any other flame sencing device on the furnace
tgd49er is offline   Reply With Quote
Old 12-08-2010, 12:22 PM   #2
ok when your furnace dies there should be a blinking led light its going to be blinking a code. and on your front panel it will say what that code means. thats where your promblem is. and it sounds like it might be either your flame proving sensor located on the opposite side from your hot surface ignitor. the only way to test that is with a volt and ohm meter.
the other posiblity is your pressure switch. then you would have to test the switch and if its good then you need a manometer to test it. thats where you probilly need a tech to go out there.
hvac kid is offline   Reply With Quote
Old 12-08-2010, 05:37 PM   #3
AKA HVACTECHFW
Rewards Points: 1,208
the HSI might act as your flame sensor. it maybe the control board, the replacement has been updated and includes a flame sensor if yours does not have one
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Lennox Furnace burner won't stay on stevea7777 HVAC 64 03-09-2017 05:39 PM
bryant gas furnace burner wont stay on. pipebender HVAC 29 11-08-2009 07:41 PM
Oil burner will not stay on Coldman HVAC 12 04-01-2009 10:12 PM
Broken Burner Fix mikelbeck HVAC 2 01-16-2009 09:05 PM
Furnance burner won't stay on. 2007ken HVAC 11 03-03-2008 11:29 PM
