Burner Doesn't Light Up - HVAC - DIY Chatroom Home Improvement Forum
Old 10-24-2008, 09:21 PM   #1
Burner doesn't light up
I have a comfortmaker GUJ075N12A1 furnace. My pilot light stays lit and everything cycle through as it should. However, my burner will not light up. I've checked my theromstat and tried cleaning the connection from the thermocouple to the valve. Any ideas what could be causing this problem? Thanks in advance!
1bud is offline   Reply With Quote
Old 10-24-2008, 09:50 PM   #2
That unit does not have a theromcouple.
Describe what you removed from the furnace to clean.
hvaclover is offline   Reply With Quote
Old 10-24-2008, 10:13 PM   #3
I cleaned the brown line located on top of the thermocouple gas valve in the enclosed picture. Thanks!pilot lights, but not burners-valve.jpg
Old 10-25-2008, 12:11 AM   #4
that is a mobile home furnace,
The number you gave me was for a residential furnace that has a auto ignition. You playin' me?
Old 10-25-2008, 12:28 AM   #5
Sorry, I am not. That was the closet picture I could find on the net that showed a similar item I cleaned. Maybe, the picture on this site will help. The line I cleaned hooks up to the slot on the left hand corner.
http://americanhvacparts.com/Merchan...tegory_Code=gv
Old 10-25-2008, 09:26 AM   #6
That model number crosses to a auto liteing system thsy has no pilot or thermocouple.
Old 10-25-2008, 09:41 AM   #7
the Musigician
DangerMouse's Avatar
it sure is ..... it's MINE! roflmao (thought that pic looked familiar)
all better now, thanks to SD515 and all the guys here. above what is shown is a chewing tobacco tin shaped pressure switch with two soft rubber tubes going to the updraft tube, pop those off and be sure they're clean. if they are, put tubes back and turn on furnace, tap on the switch with a screwdriver or something gently. if it works, you have my problem. test for 24v at that switch too.
DM
Old 10-25-2008, 09:54 AM   #8
That model number crosses to a auto liieinng system thsy has no pilot or thermocouple.
Which model number? The furnace or thermocouple gas valve? I cleaned the wire the leads to the bottom on my burner and I have a Honeywell thermocouple gas valve model GSV800A1476A. I'm new to this so sorry for the confusion. It happens to be the exact model listed on the website below.
Old 10-25-2008, 10:23 AM   #9
I am refering to the name and model number you posted for the furnace..
Old 10-25-2008, 11:34 AM   #10
I have two models numbers listed on my Comfortmarker furance. The first one is GUJ075N12A1 and the second one is NU63075AFA1. Thanks!
Old 10-29-2008, 05:46 PM   #11
Looking at your picture the gas is off do you realize that (you would be surprised at how many service calls with gas off)? If so check voltage at valve when thermostat is calling for heat should work. If you have 24 volts at valve then you have problems with valve.
simpleman
simpleman1962 is offline   Reply With Quote
Old 10-29-2008, 05:49 PM   #12
1bud
By the way from your pictures your unit does have a thermocouple to keep pilot lit.
Old 10-29-2008, 05:57 PM   #13
the Musigician
please read post #7 simpleman, that is a pic he found online of MY furnace, and yes, the gas was off as i was preparing to pull the burner out.
MY furnace! MY multimeter! MY crappy hallway carpet! roflmao
DM
Old 10-29-2008, 08:37 PM   #14
DM
Nothing like getting beat up and told about your OWN furnace.ROLF
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 11:40 AM
Marmoleum repairs muggyfrost Flooring 8 10-16-2008 09:19 PM
Light Socket Won't Hold Light Bulb colhollywood Electrical 3 08-16-2008 09:28 AM
Need to replace can light with standard light Woodcutter Electrical 3 02-29-2008 08:06 AM
