Burner Crapped Out - New GO-3 Burner Adjustment - HVAC - DIY Chatroom Home Improvement Forum
Old 01-10-2010, 07:35 AM   #1
Burner crapped out - New GO-3 Burner Adjustment
Burner crapped out and just installed a new GO-3 burner in a WC WGO-3 boiler. Are the factory settings on the GO-3 burner 'good enough' to run it for the next few days until I can get a service tech out to properly adjust it? I could get someone today, but I don't see the need to pay an emergency call fee if I can run this thing until tomorrow or Tuesday as is.
hollybrook is offline   Reply With Quote
Old 01-10-2010, 07:50 AM   #2
An old Tradesmen
Rewards Points: 7,816
May or may not be.
Depends on the chimney and how clean your boiler was before the new burner was installed.
New burners shouldn't be installed in a dirty boiler. Did you clean the boiler before installing the new burner.
Might want to have a tech clean the boiler. Burner set up is part of the process.
Old 01-10-2010, 08:42 AM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 150
If it is burning too lean can it produce creosote Beenthere? Saw that happen once and it made a HE*L of a mess of a furnace AND chimney and can be very dangerous.
Old 01-10-2010, 09:09 AM   #4
An old Tradesmen
Too clean or too dirty both cause lots of trouble.
Too clean can form a tar(similar to creosote) in the flue and chimney.
And cause a chimney fire down the road.
Also can cause sulfuric oxide vapor to form. And if it mixes with moisture. You have sulfuric acid(nasty stuff).
And if it washes down into the boiler. It does lots of damage.
Too dirty, and it can soot up the boiler passage ways that you get CO coming out of the boiler.
Less harmful is the increase in oil consumption. Since soot is a good insulator.
The OP, may be thinking. but its only for a day or 2.
How far off the air fuel mixture is. will vary how much damage can be done in a day or to.
A # 6 smoke can soot up a boiler in a day(3/16 to 1/4". A #10 can plug it up in that same time period.
Would be best to use space heaters until a tech can clean the boiler, and set up the burner properly.
The OP has to make that decision.
Guess it depends on how lucky the OP feels. OP: Have you won the lottery recently?
Old 01-10-2010, 09:45 AM   #5
Hvac Pro
yuri's Avatar
Rewards Points: 150
Yeah. It can be sooted up in less than a day (same with a gas furnace) and it costs $$/hr to clean it. More soot=more hrs=more cost. Back in the Dark ages (1979) I saw a furnace and chimney get completely tarred up with the tar oozing down out the cleanout. Not sure if you ever heard of a low pressure gun type oil burner (obsolete) not sure if it was a Timken, looked like a gun type if I remember, but they stuck a high pressure one in and the furnace was not designed for it. Long story short, it tarred everything up and we had to do a changeout to gas ASAP. What a MESS!!
Old 01-10-2010, 10:03 AM   #6
An old Tradesmen
GE, Timpkin, York Shipley. To name a few.
I hated those GE compressors. They only died after the supply house was closed.
Old 01-10-2010, 10:18 AM   #7
Hvac Pro
yuri's Avatar
Rewards Points: 150
Nowadays my hands only get dirty on "special occasions". The grease from the Big M*acs used to be great for loosening up the oil grime under the fingernails. Those were the days. Saw an original Timkin brand boiler (fancy shroud etc) a month ago with an upshot gas conversion burner. Timken was the Cadillac of the day.
Old 01-10-2010, 10:21 AM   #8
An old Tradesmen
Haven't seen a working low pressure in several years now.
Lots of converted GE's though.
Old 01-10-2010, 02:25 PM   #9
I cleaned the boiler, flue pipe and chimney about 2 weeks ago and installed a new refractory kit. The thing has been a little 'sooty', so didn't want to rely on trying to duplicate the settings on the old burner. Guess I could run it for a bit, open it up and see what I got. Trying to get someone out here in the morning, but you know how that goes.
Space heaters are out of the question. In this frigid NE weather going on space heaters just ain't gonna get the job done.
Old 01-10-2010, 05:33 PM   #10
An old Tradesmen
keep your fingers crossed.
monitor heater repair help speakers3 HVAC 16 01-18-2015 04:00 AM
Pressure Switch, Draft Inducer, Burner Box, Problem majorapus HVAC 7 10-25-2009 06:14 PM
Oil burner will not stay on Coldman HVAC 12 04-01-2009 10:12 PM
Broken Burner Fix mikelbeck HVAC 2 01-16-2009 09:05 PM
Question about gas burner design darsunt HVAC 4 12-14-2008 01:37 PM
