Old 09-18-2007, 06:58 PM   #1
Default Burner on Bryant furnace won't come on
Hi all,
I have a Bryant model 397H (1980's). The Furnace (AC actually) had a condensate leak last spring and I replaced the Main Board and the wiring harness. Now (fall) I checked Heat functions for the winter and discovered the main burner won't ignite. AC functions are fine. When you call for heat... the inducer runs, the pilot ignites but thats all. The Pilot continues to spark for about 25 seconds and then the 3amp (auto-style) fuse on the main board blows. If I pull the Green wire from the MFV (main fuel valve) then the igniter stops and the pilot continues to burn. I show 26V on the brown wire at the mfv. I jumpered the orage wires (resetable draft switch?) and the red wires (over temp) with no improvement. Any one with Bryant experience have any suggestions?
Adam
Flylowflyslow is offline   Reply With Quote
Old 09-19-2007, 02:57 PM   #2
Default I Fixed it
Well I read my own post this morning and realized that the short that took out the circuit board and the wiring harness probably shorted the fuel control. I replaced the fuel control ($125 ouch) and all is well.
Thanks to anyone who was pondering a response.
Adam
More On This Topic
Before you call someone to come fix your furnace, you may want to find out what's wrong. Read on to learn how to check your furnace for any possible malfunctions. Read More »
Hi, I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. Something else you want to think about if you do decide to finish your basement in stages, is access to the plumbing and heating. If you decide to finish... Read More »
About Car Wires & Fuses
About Car Wires & Fuses by Expert Village
Hi! I'm Robert Wilkins from the Car Alarm Shop and we are covering basic automotive wiring part 2 for Expert Village and what we are going to go over now is how the vehicle is powered. This is the automotive battery. Of course, you've got positive and... Read More »
Hi! This is John again. Now, I’m going to be talking about setting up to do your casting. You’ll need some different items to start with. Number one, you’ll need an electric furnace. This happens to be a small lead precision furnace... Read More »
Hi! I'm George Stonebrook for Expert Village here to talk to you today about preventing theft of your vintage car. The first thing you want to do in preventing theft to your car is to sable as easiest you can. One of the ideas is to take your distributor... Read More »
Heil Furnace Burner Problem timothyr HVAC 65 10-26-2009 05:49 PM
Bryant Furnace main burner goes out after 5 seconds Da_Bears HVAC 4 01-26-2008 10:20 PM
Bryant Furnace NO Heat DMG HVAC 0 09-16-2007 05:04 PM
Bryant gas furnace non startup homer12 HVAC 4 12-14-2006 10:30 PM
Burner won't fire on Payne 490AAV furnace lwhpops HVAC 2 10-20-2006 05:03 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
