-   -   Burner Air Supply - Negitive Pressure Home (http://www.diychatroom.com/f17/burner-air-supply-negitive-pressure-home-14631/)
taglaser62 12-20-2007 09:31 PM
I have a Rheem 90 high efficiency furnace. I have been told that it creates a negitive pressure in the home when it sucks air out of the home for combustion and then blows it outside via the exhaust. I understand this and can believe what I'm told. Here is the question: should I run an air supply tube from outside to my furnace so that home air pressure is neutral? pros & cons please?
Buckeyetech 12-20-2007 09:47 PM
Most 90 percenters have two pvc pipes going into the furnace. One is the air intake and the other is the flue gas exhaust.
taglaser62 12-20-2007 09:50 PM
yes i see it there. should I pipe it to outside? what is benefit?
bigMikeB 12-22-2007 09:06 PM
Not using inside air for combustion is the benefit. Outside air for combustion makes less carbon monoxide than using inside air. Pipe it outside.
