Burham Holiday Boiler Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 10-15-2009, 09:42 PM   #1
Burham Holiday boiler furnace
I have a old Burham Holiday boiler 6-w-20 series 2, the burner will not shut down and pressure release valve blows at about 32 lbs, the wall thermostat can be all the way down but it still happens. thanks for the help !!!
american501 is offline   Reply With Quote
Old 10-15-2009, 10:20 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
I'll say this as nicely as I can
SHUT IT DOWN AND SHUT IT DOWN NOW!!!
With burners not shutting down you could be low on water, expansion tank faulty, limits not working, aqua-stat not sencing temp. I would ask you to call a pro. If the temps get too high this boiler can blow.
I understand this is a DIY site and while all for that when a boiler is raising the pressure and actuating the TPV then this is serious and not a DIY project.
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
50+yr old Burham boiler guysr1 HVAC 1 09-24-2009 05:49 AM
Gas Boiler furnace or a new system? paulssn HVAC 1 08-29-2009 10:02 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
Home oil boiler furnace jmb HVAC 5 03-28-2007 07:03 AM
