Built In Thermostat Vs Wall Mounted Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 09-28-2009, 01:06 PM   #1
Built in thermostat vs wall mounted thermostat
Hi All,
I recently purchased a house and plan to convert the heating from oil to electric. I'm currently looking at getting convection heaters to replace the water heaters and wanted to know of any experiences with built in thermostats on these units (home depot carries the dimplex models) vs putting it on the wall.
Any thoughts or experiences would be appreciated with build in thermostats
reno_guy is offline   Reply With Quote
Old 09-28-2009, 03:56 PM   #2
An old Tradesmen
Rewards Points: 6,140
Wow. What is your electric rate. In most areas, oil is still cheaper to heat with then electric baseboard heaters.
Stats on walls tend to make for a warmer more comfortable room.
Old 09-28-2009, 10:27 PM   #3
Electric rate is about 7.5 cents a kw hour. Looking for less maintenance and the insurance companies seem to no longer cover oil damages in the house...
so if the oil tank breaks... don't know what will happen
Old 09-29-2009, 04:52 AM   #4
An old Tradesmen
If thats with all taxes and delivery fee's included. Electric sounds the way to go.
Old 09-30-2009, 12:54 AM   #5
Hi i am installing in floor radiant heating systam. with combined hot water indirect hot water tank i need some help in how to install indrect hot water tank in my systam
kvdiesel is offline   Reply With Quote
Old 09-30-2009, 12:59 AM   #6
building a wall against an exterior wall Mike L General DIY Discussions 2 08-20-2009 03:50 PM
Loads on a partition wall acyate Building & Construction 8 03-01-2009 12:02 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
Trying to replace wall mounted light fixture jtm2300 Electrical 4 08-03-2007 10:44 PM
