Building An Refrigeration Unit - HVAC - DIY Chatroom Home Improvement Forum
Old 01-13-2012, 04:02 PM   #1
building an refrigeration unit
Hello everyone,
I'm new to this site, though I'm as much of a diy'er when I can be. I need some HVAC advice. I want to build a propyelene glycol chilling system. I've heard of people just using a window a/c unit, and putting the evap coils into the glycol tank, but the casing on the coil unit starts to rust and then clogs the glycol pump. I'd also just like to build one that's larger than you could do with a window unit.
My question is, where could I find enough information to build a unit from scratch? I understand the basic refrigeration cycle and have have an idea of what parts I'd need, I just know nothing about part compatibility or the size/length of coils I'd need on each side. Where can I get enough information to do this? I'd like to build between a 6K and 10K btu system, btw.
Thanks for any and all help!
rtockstein is offline   Reply With Quote
Old 01-13-2012, 04:55 PM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by rtockstein View Post
...but the casing on the coil unit starts to rust and then clogs the glycol pump.
You'll probably need to make your own coil...
using something (stainless? aluminum?) that doesn't react to the chemicals.
My question is, where could I find enough information..
I just know nothing about part compatibility...
start with an Aireco catalogue
http://www.aireco.com/
Old 02-10-2012, 07:27 AM   #3
Yea, if I were to build a unit from scratch, I'd be building my own coil. The problem is I wouldn't know how to figure out what length and diameter of tube I'd need.
I'd just use copper though, since copper oxidation isn't flaky and awful like the rust is that would be coming off the galvanized casing (or whatever it's made of).
I found out that I'd need a 1 to 1.5 HP compressor, which equates to being able to handle a 5500 to about 7500 BTU load. Anyone know where I can find out how to build one to those specs?
Old 02-10-2012, 07:21 PM   #4
MarginallyQualified
I found out that I'd need a 1 to 1.5 HP compressor...
Based on what?
It's usually a function of "exposure" (how many square inches of surface per linear foot) relative to the space available.
When I was doing custom S/S fab we built refrigerators and freezers and frost over display things for buffet lines using either standard ACR copper tubing bent by hand or copper pipe with 180' U bends at each end.
hth
Old 02-10-2012, 08:04 PM   #5
PE Mechanical Engineer
Thunder Chicken's Avatar
Rewards Points: 844
Just use a window AC unit - you can get those in 10k and larger sizes. Pull out the finned evaporator coil and replace it with either stainless or copper loops, using the same diameter lines. If you are immersing this coil in liquid glycol heat exchange shouldn't be an issue.
I would try to estimate how long the primary evaporator line is (without the fins) and use that to size your new coil. Then just stick the thermostat in the glycol, set the temp and let er' rip. Just make sure the glycol is circulating well.
Thunder Chicken is offline   Reply With Quote
What is the price difference between a 2.5 ton unit and a 3 ton unit? Leoskee HVAC 5 06-12-2014 12:00 PM
Ruud Pack unit "KABOOMS" upon First Light Up of the Day! Wirenut2tite HVAC 18 12-15-2012 10:11 AM
What Temps Should York AC Unit Be? - Is it Me or Does my AC kind of work? mrpman HVAC 7 07-24-2011 06:59 PM
Carrier Condenser Unit Screwed? gimmes name HVAC 6 07-24-2011 07:05 AM
Replacing a condensing unit with a higher SEER rating unit tylanz HVAC 3 06-28-2010 04:44 PM
