Building A PVC Condensate TRAP - HVAC - DIY Chatroom Home Improvement Forum
Old 07-10-2012, 09:52 AM   #1
biggles's Avatar
building a PVC condensate TRAP
most of the time their shallow with a store bought formed piece of pipe.the trap doesn't need to be over the emergency pan and can actually be elbowed out of the unit with the first piece of pipe after the T clean out.so for it to be outside that pan you will get the drop required for a true trapping.between the RED lines you want a minmum of 1"(don't need more)the clean out should have a cap...for seasonal blow out of muck/dirt
p trap problem chrishulett Plumbing 8 01-28-2011 06:52 AM
Condensate Pump confusion GlennAndrew HVAC 9 01-01-2010 06:25 PM
Clear PVC pee trap for condensate - Where do you buy? zootjeff HVAC 3 07-12-2009 11:52 AM
Cat trap fever radtek General DIY Discussions 13 05-31-2009 07:18 PM
clogged pipe or trap issue? windowguy Plumbing 3 05-10-2009 11:10 AM
