Building Into Garage - HVAC - DIY Chatroom Home Improvement Forum
Old 11-11-2007, 12:33 PM   #1
Building into garage
I am building a great room/game room in my garage taking out the garage door and enclosing it with walls and windows and am wondering if I need to have any ventilation system under the flooring. I plan to attach vents to the existing heating system of the house; putting in I-joists with subflooring and hardwood on top of that. I have had some suggest that I need some kind of system in order to take care of humidity/condensation. Any ideas?
JimW is offline   Reply With Quote
Old 11-11-2007, 03:21 PM   #2
so-elitecrete
Rewards Points: 150
have you done,,,
a moisture test of the existing floor yet ?
so-elitecrete is offline   Reply With Quote
Old 11-12-2007, 04:13 PM   #3
No actual test. It seems to stay pretty dry except for a little under the garage door (which will be replaced with a wall) when it rains and blows from that direction. Otherwise, it's dry.
Old 11-12-2007, 04:25 PM   #4
so-elitecrete
Rewards Points: 150
my error - sorry,,,
tape down a 2.0 x 2.0 piece of plastic w/duck tape for 24 hrs,,, see what, if any, moisture collects 'tween the plastic & the existing floor,,, apologies for the incomplete,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
Old 11-14-2007, 09:17 AM   #5
Moisture test
OK, so I did the moisture test ... and it was completely dry. So do you think I need any kind of ventilation under the flooring??
Old 11-14-2007, 01:27 PM   #6
so-elitecrete
Rewards Points: 150
nope, i don't think you do, jim,,, still to be safe, i'd install p/t 2x4s on edge,,, then cover w/6mil plastic sheeting.
btw, is there a floor drain in the room ?
Old 11-14-2007, 01:57 PM   #7
Mod / ArchiBuilder
Cole's Avatar
Jim, where are you located?
I agree with the above poster, I would do the same, especially if you are going to go with a hardwood for the floors.
Cole is offline   Reply With Quote
Old 11-14-2007, 03:33 PM   #8
Sounds like a good idea. Thanks. No floor drain.
I am putting in hardwood floors.
I live in central Iowa.
New Heated Garage: need help! HardcoreCBR General DIY Discussions 12 05-23-2008 08:34 AM
Crazy Garage Extension, Building over blacktop?!?! commissure General DIY Discussions 4 09-13-2007 12:09 PM
Converting Carport to Garage viking1974 Building & Construction 2 08-12-2007 11:38 PM
Building garage with elevated concrete floor dmj245 Building & Construction 13 05-31-2006 05:13 AM
