-   -   Building into garage (http://www.diychatroom.com/f17/building-into-garage-13288/)
JimW 11-11-2007 11:33 AM
I am building a great room/game room in my garage taking out the garage door and enclosing it with walls and windows and am wondering if I need to have any ventilation system under the flooring. I plan to attach vents to the existing heating system of the house; putting in I-joists with subflooring and hardwood on top of that. I have had some suggest that I need some kind of system in order to take care of humidity/condensation. Any ideas?
so-elitecrete 11-11-2007 02:21 PM
have you done,,,
a moisture test of the existing floor yet ?
JimW 11-12-2007 03:13 PM
No actual test. It seems to stay pretty dry except for a little under the garage door (which will be replaced with a wall) when it rains and blows from that direction. Otherwise, it's dry.
so-elitecrete 11-12-2007 03:25 PM
my error - sorry,,,
tape down a 2.0 x 2.0 piece of plastic w/duck tape for 24 hrs,,, see what, if any, moisture collects 'tween the plastic & the existing floor,,, apologies for the incomplete,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
JimW 11-14-2007 08:17 AM
Moisture test
OK, so I did the moisture test ... and it was completely dry. So do you think I need any kind of ventilation under the flooring??
so-elitecrete 11-14-2007 12:27 PM
nope, i don't think you do, jim,,, still to be safe, i'd install p/t 2x4s on edge,,, then cover w/6mil plastic sheeting.
btw, is there a floor drain in the room ?
Cole 11-14-2007 12:57 PM
Jim, where are you located?
I agree with the above poster, I would do the same, especially if you are going to go with a hardwood for the floors.
JimW 11-14-2007 02:33 PM
Sounds like a good idea. Thanks. No floor drain.
I am putting in hardwood floors.
I live in central Iowa.
