Buffer Tank Aquastat? - HVAC - DIY Chatroom Home Improvement Forum
Old 11-13-2012, 05:21 PM   #1
Buffer tank aquastat?
I want to make an indirect water heater into a buffer tank to supply my floor heat. If I want the buffer tank to have a low limit of 100 and a high limit of 180, how would you accomplish that with an aquastat?im basically looking for a high limit aquastat with an 80 degree differential. Most aquastats have a max 30 degree differential. Thanks
Akridgepointe is offline   Reply With Quote
Old 11-14-2012, 05:55 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 334
Ayuh,... In floor radiant heat usually uses water at 150 to 170....
Donno why you'd want the buffer to call for heat at 100, which is too cold, or shut off at 180 which is atad high...
Old 11-14-2012, 11:26 AM   #3
My in floor radiant supply temp is close to 100. It varies based on outdoor temp, it has an injection mixing valve. It is a constant circulation system. If I have a buffer tank at 180, the injection pump can make 100 degree water for a long time. That tank would be usable almost down to 100 degrees, at that point the injector pump would be running and near 100 percent ( and ready for more heat)
Old 11-14-2012, 02:02 PM   #4
Rewards Points: 380
Likely easiest to just use 2 controls. Your supply temp to the floor at 100 is good, most piping manufacturers recommend less than 120 going into the floor as it creates too much stress on the piping if it is heated past 120 and can crack the pipe and/or possibly crack the concrete.
HVACDave is offline   Reply With Quote
Installation and support of water heater expansion tanks. Homerepairguy Plumbing 46 01-28-2013 06:55 AM
plumbing geothermal to buffer tank chulett HVAC 0 10-21-2012 11:13 PM
questions about plumbing hot water tank bubbler Plumbing 13 01-18-2012 07:43 AM
Septic tank missing T and badly angled main line? denemante Plumbing 3 11-22-2011 10:29 AM
Nightmare water tank job Marvin Gardens Plumbing 6 11-04-2008 12:09 PM
