Bryant Plus 90 Problem - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-27-2012, 08:58 PM   #16
Rewards Points: 616
sorry I forgot about all the lady tecs....
carmon is offline   Reply With Quote
Old 09-27-2012, 09:34 PM   #17
Rewards Points: 582
Originally Posted by carmon View Post
gentlemen.... this is very concerning to me.... I do not believe we should be advising anyone to jump a pressure switch on a furnace an air conditioner go ahead everyone will live.. .. we are dealing with a dangerous fuel hear...lets be care full....
see post 8 great minds think alike...
Old 10-01-2012, 03:26 PM   #18
Thank you all!!!
To all of the people who gave me information and warned me about the danger, I fixed the problem. I received the new pressure switch today that I purchased on eBay for $30.00 and hooked it up. The furnace still gave me a code 31. My next step was to remove the PVC pipe from the induction draft motor and checked it for obstruction. Upon first glance I noticed some feathers coming out with a little water. So I thoroughly checked the pipe to find it was clear. I then stuck my finger into the induction motor housing and sure enough I felt feathers. I grabbed my needle nose pliers and pulled out a bird that had been in there a while. I wanted to get it completely clean so I removed the ID motor and took it outside to pull it apart and clean it out. Once outside I decided not to pull it apart since it was sealed with silicone. I then noticed more feathers further into the housing and sure enough, another bird. I got a little mirror I use for working on cars and stuck it in the housing to make sure there was no other obstruction. It was all clear at this point. I re-installed the ID motor and all the pipes and hoses and electrical connections, fired it up and it works like a charm. Even the ID motor barely makes a sound. Thank you all for the info. I greatly appreciate it. Have a great day.
sixstrings24 is offline   Reply With Quote
Tags
bryant , furnace , heating , pressure switch , propane
Bryant model 395cav blower problem. IkeandTina HVAC 8 11-12-2011 05:25 PM
Need Help Fixing Damp Slab Problem in Shop OlyTDI Building & Construction 10 10-30-2011 12:35 AM
75 year chimney leak problem mstanleyg Building & Construction 10 03-30-2010 12:38 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
