-   -   Bryant Plus 90 Problem (http://www.diychatroom.com/f17/bryant-plus-90-problem-158100/)
sixstrings24 09-26-2012 09:10 PM
I have a Bryant Plus 90 furnace propane that worked once since I turned it on a few days ago and hasn't since. The fan works and the thermostat works. I get code 31 whenever I attempt to start the furnace. The, for a lack of a better term, "little" blower motor comes on and the LED stays lit for about 30 seconds then blinks. 3 fast 1 slow, code 31. I ran a continuity test on the pressure switch terminals and started out with infinity and resulted in infinity. I then checked the air intake PVC pipe and there is no obstruction. I then pulled all the hoses off and blew through them to find they are clear of debris. I checked the condensation trap...empty. My conclusion is the pressure switch is bad.
Am I wrong in thinking this?
Is there another possibility?
Is there any way I could bypass the pressure switch until the new one arrives?
I live in northern Wisconsin and the nights have been getting pretty cold. I would just like to heat the house up for an hour or two and then shut it off for the night. We have a pretty air tight house so the heat stays for a while. Also our furnace is not within the house itself. It is in the attached pole building.
carmon 09-26-2012 10:19 PM
make sure tubes to pressure switch and ventor motor have no obsructions.... if you read 24 volts when ventor motor running pressure switch is open ...may be a bad switch may not be ...lots of things can cause a switch not to close.. the info on furnace should tell you what code 31 means .... i forget what i had for breakfast so i cant help with code 31..
Mr.HVAC 09-26-2012 10:20 PM
sixstring,
code error 31 indicated faulty high pressure switch. Something is obstructing the vent or the switch might be bad it self. If you are sure that the exhaust vent are not obstructed, then yes you can test the pressure switch by jumping. Turn on heat, and once the induce draft motor (vent motor) starts, immediately jump the two wires together with a jumper wire, you don't have to take the wires off of the switch, just move it out enough to where you can clip your jumper wire.
how 09-26-2012 10:26 PM
Also..
(1) Check the exhaust vent for an obstruction.
(2) Remove the PS hose from your ID and use a staightened paper clip to explore inside the ID port it was attached to for a build up.
carmon 09-26-2012 10:28 PM
there you go ...younger and smarter minds have responded... well done :thumbsup:
sixstrings24 09-27-2012 07:18 PM
Thank you!!
Thank you all for the responses. I am about 98% positive the pressure switch is bad. I jumped the leads on the switch and the burner lit up and ran for around 5 minutes until I removed the jumper and the burner shut off. I figure the burners could not stay lit if there was something obstructing the vent pipe which I had already checked previously. This is my first time working on a furnace but the knowledge I gained will help me in the future. Thank you all for the input :thumbsup:.
carmon 09-27-2012 08:04 PM
It is a very poor idea to run the furnace with the pressure switch jumped.... there could be something in the pipes thats the switchs job... it is probably bad replace it.... and you will find out
ben's plumbing 09-27-2012 08:09 PM
fully agree with carmon ..don't run furnace with any of its safety switches jumped out......that is why I personally don't suggest jumping these out because many will leave it like that.... test it with a meter.. either replace it if its bad or put it back if its not....ben
Mr.HVAC 09-27-2012 08:14 PM
good luck sixstring,
the reason why the burner lit is because you bypassed the switch. So even if it is obstructed, it will lit. I hope that the switch is bad base on the information you provided. If a new one does not solve it, then you definitely got something obstructed that you did not see. LIke other said, don't run the furnace using the bypass method. good luck
ben's plumbing 09-27-2012 08:24 PM
if you remove the pressure switch from system....the furnace could run till high levels of carbonmonixide are present....because the part that shuts it off due to a restriction or clog is no longer able to do it job?????
sixstrings24 09-27-2012 08:25 PM
Thank you Mr. HVAC. I just ordered a new one from eBay for $30.00. I should get it by next Tuesday. If that doesn't fix the problem then I will have to remove the vent pipes which will be tough since they are going through the wall. I might just see if I can't get my hands on a plumbers snake and feed it through the pipes to clear any possible obstructions I could not see from looking down the external end of the pipe.
I did run the furnace to heat up the house for about 30 minutes. Nothing seemed to go wrong. I kept a close eye on it and a hand on the propane shut off valve. :thumbup:
sixstrings24 09-27-2012 08:32 PM
I checked the vent pipe outside and there was air coming out. Our furnace is located in a bathroom in our attached pole building. With the door shut it is completely shut off from the house and the pole building. That and I could feel cold air coming in through the duct where the filter sits.
how 09-27-2012 08:36 PM
It will take you one minute to remove the PS suction line from the ID and see if you have a build up inside the ID port. It's a common issue.
You might of already checked that out with a paperclip and just didn't mention it.
Mr.HVAC 09-27-2012 08:41 PM
You're welcome sixstring,
whatever you do, please don't run it using the bypass method. In fact, take off the jumper wire and unplug the furnace so that your family don't accidently turn it on while you are away. Let us know once you install a new. Oh by the new, don't blow into the pressure switch, that will damage the diaphram (sp).
carmon 09-27-2012 09:02 PM
gentlemen.... this is very concerning to me.... I do not believe we should be advising anyone to jump a pressure switch on a furnace an air conditioner go ahead everyone will live.. .. we are dealing with a dangerous fuel hear...lets be care full....
