Bryant Plus 90 Intermittent Ignition - HVAC - DIY Chatroom Home Improvement Forum
Old 04-09-2010, 12:21 PM   #1
Bryant plus 90 intermittent ignition
Hey guys
I have a byrant 90 from about 1992, it ran fine until a few months ago. From then on I have an intermittent ignition problem. From what I can tell the unit has a spark ignition that ignites the pilot light and that ignites the burners. The problem I am having is that the induction fan run about 30 seconds and turns off, but no ignition happens. I have checked the vacuum switch by taking the hose off and sucking on it and it does click. Some times it will not work all day and other times it will work fine for a week. It seems that when it is cold outside below 40 degrees it does not want to work anymore, but when it warms up a little it will work fine. I tried to take a look at the pilot light area but it is buried deep and I can't see it. Does anyone have any idea what it could be or maybe have a link to a repair manual so I can further diagnose it myself, I am a automotive engineer but I have not messed with furnaces before so a manual should be enough for me to diagnose it.
Thanks in advance
miguy
miguy is offline   Reply With Quote
Old 04-10-2010, 09:30 PM   #2
i know this is going to sound stupid, but take out your burners and clean them real good, take some sandpaper to your sensors and clean it as well, you got to start simple and move to the more complicated
tamar120 is offline   Reply With Quote
Old 04-11-2010, 11:31 AM   #3
sure I can do that, but how do I do that. Anyone got some step by step or something. I just want to know how far I have to go or I don't want to take something apart I shouldn't.
REZNOR gas shop heater WHOOMP ! on ignition Wildcat355 HVAC 14 01-29-2010 06:57 PM
Gas valve on a bryant heavyduty HVAC 1 12-16-2009 09:42 AM
first time startup on Bryant furnace - furnace calls for heat and will not stop luvheat HVAC 22 02-14-2009 09:56 AM
This may help someone with carrier ignition problems AweMan HVAC 15 02-09-2009 02:20 PM
furnace ignition troubleshooting buju HVAC 22 01-14-2009 11:41 PM
