Bryant Plus 90 Igniter - HVAC - DIY Chatroom Home Improvement Forum
Old 02-15-2012, 07:09 PM   #1
Bryant plus 90 igniter
How do you get the igniter out without taking the burner apart? The flue pipe runs in front of it. Also there are no screws that hold it in that I can see from the bottom.
Johnny81 is offline   Reply With Quote
Old 02-15-2012, 07:21 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
PAIN IN THE A**!!!! you need to remove the intake pipe out of the way. May require cutting the pipe and using a rubber coupling to put it back together. Hopefully the installer did not glue the pipe to the burner box intake.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
The Following User Says Thank You to hvactech126 For This Useful Post:
ben's plumbing (02-15-2012)
My Trane Igniter Burnsout condorseahorse HVAC 5 12-01-2011 08:06 PM
Bryant Warranteed heat exchangers issues TruckTahoe HVAC 0 02-14-2011 02:21 PM
Rheem No 120VAC Igniter Help Benihana HVAC 5 01-04-2010 03:39 AM
Bryant Gas furnace 383KAV - No heat labrat HVAC 2 10-11-2009 11:11 PM
first time startup on Bryant furnace - furnace calls for heat and will not stop luvheat HVAC 22 02-14-2009 08:56 AM
