Bryant Plus 90 Fuse Replacement - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-11-2008, 08:14 PM   #16
Originally Posted by kennzz05 View Post
open your pack of cigarettes remove small piece of foil wrap fuse in foil reinstall now your furnace is like 75% of the rest them out there
WHAT?
If you are doing that you don't belong in this business. That fuse is there for a reason you dope. And that is to protect the electronics and other components from overload.
hvaclover is offline   Reply With Quote
Old 11-11-2008, 08:20 PM   #17
HvacWiz's Avatar
Rewards Points: 252
What he said
HvacWiz is offline   Reply With Quote
Old 11-11-2008, 09:23 PM   #18
blah blah blah and you know soooo much it works and at 12:00midnight if its all ya got than im doin it and you dont belong in this biz if you cant improvise there are ways to determine if theres a short and if its unsafe but ill let u figure out what that is
hey hvac lover arent you the one that said R to W was a short um yea sure it is
hvaclover quote:
Where'd go, Europe? It's been ten days since your post.Any thing is posisble. Touching r and w at furnace will blow the stat.
Need alot more info then you are supplying.
Are burners comming on?
Just slow, not stupid
sorry you said blow the stat really please elaborate
kennzz05 is offline   Reply With Quote
Old 11-11-2008, 09:31 PM   #19
HvacWiz's Avatar
Rewards Points: 252
First day here and allready starting trouble..lol
Old 11-11-2008, 09:41 PM   #20
well if attacked i am quite opinionated
Old 11-12-2008, 12:00 AM   #21
dgbehrends's Avatar
Rewards Points: 150
Send a message via Yahoo to dgbehrends
Hmmmm............I guess I would have to pick up the habit then
D in MN
dgbehrends is offline   Reply With Quote
Old 11-12-2008, 05:40 AM   #22
Electrician
SD515's Avatar
Rewards Points: 504
I thought kennzz was joking with this one. (though I know it could be done in a pinch)
Kyle
Old 11-12-2008, 09:57 AM   #23
hvaclover quote:
Let's clear the air here,
At 12 midnight I would have a fuse with me. It's a stock item you buy in quantity..big quantities. I won't use foil to jump a blown. I also carry in my tool bag a mini breaker that I can reset til I locate the short. So my first endeavor would be to amp out all the wiring with the mini breaker in place, not just replace a fuse with out locating the fault caused it to blow.
Aluminium foil is going to do what for you? Burn up the parts that the fuse was protecting.
And as to your query about jumping out r and w at the furnace with out removing one of the wires beforehand you will short out the stat.
I am sure you are no dope, but that statement rubbed me the wrong way and is definitely not a good practice as I am sure you know. In a pinch carry a mini breaker.
Old 11-12-2008, 10:20 AM   #24
please allow me to apologize and consider the hatchet buried
Old 11-14-2008, 09:51 AM   #25
Damn it! Next time shave, will'ya?
Fuse Boxes For Showers Petrena Electrical 3 09-13-2008 01:36 AM
Problems with new fuse box for a dryer. needsomehelp Electrical 12 04-10-2008 11:20 PM
Goodman GMT-070-4 Furnace blows 3A Fuse Bruce Mundy HVAC 4 01-02-2008 10:31 PM
Microwave Fuse Replacement - Overbilling Glasnost Electrical 13 11-18-2007 09:27 PM
