Bryant Plus 90 Fuse Replacement - HVAC - DIY Chatroom Home Improvement Forum
Old 11-10-2008, 10:20 PM   #1
dgbehrends's Avatar
Rewards Points: 150
Send a message via Yahoo to dgbehrends
Bryant Plus 90 fuse replacement
Hello and thanks for reading,
I have a Bryant Plus90 furnace model #350MAV048100
This is a picture of the sticker. http://img221.imageshack.us/img221/592/bryant6dy3.jpg
Some googling tells me the fuse on the board is a 3amp fuse, even though it has the letter E on it. Can I replace this with a typical 3amp fuse?
I found a listing on Ebay for one the title was this
ATO3 CARRIER/BRYANT GAS FURNACE CIRCUIT BOARD 3AMP FUSE
What does "ATO3" mean?
I would like to pick one up at walmart on my way home so I don't have to bundle up tonight.
I accidentally blew it while shorting R and G together trying to set the blower speed.
D in MN
dgbehrends is offline   Reply With Quote
Old 11-10-2008, 11:36 PM   #2
Try turning the fuse over. it might say three then.
hvaclover is offline   Reply With Quote
Old 11-10-2008, 11:47 PM   #3
dgbehrends's Avatar
Rewards Points: 150
That was my initial thought, but for some reason it just didn't look like a 3. However if you go with LED numbers then it's got to be a 3.
After some more searching it looks like ATO simple means a standard auto fuse. Picking one up at walmart should do the trick. The one that I have is made by littlefuse and is rated 32V. It looks like a car fuse and I might be able to borrow one out of my car if I want to save myself a trip to walmart tonight.
D in MN
Old 11-10-2008, 11:50 PM   #4
OIE! (smacking forehead with open palm)
I think you are just trying to have a little fun and are not completely serious .
Old 11-10-2008, 11:55 PM   #5
dgbehrends's Avatar
Rewards Points: 150
I edited my post (no longer 100% certain). I think my dyslexia got the better of me.
D in MN
Old 11-11-2008, 08:57 AM   #6
O h. So that must be a new drink. "O"? j/k
Old 11-11-2008, 12:23 PM   #7
Electrician
SD515's Avatar
Rewards Points: 504
1=I 2=Z 3=E 5=S 7=L 10=OI 20=OZ 30=OE
Kyle
Old 11-11-2008, 12:26 PM   #8
Old 11-11-2008, 12:29 PM   #9
Good thing it wasn't a 460 v 3 phase cartridge fuse.
Poor guy may have tried buying a shock absorber in stead.
Old 11-11-2008, 12:38 PM   #10
Electrician
SD515's Avatar
Rewards Points: 504
Roflmao!
Kyle
Old 11-11-2008, 03:06 PM   #11
dgbehrends's Avatar
Rewards Points: 150
The 50 cent walmart special did the trick.
D in MN
Old 11-11-2008, 03:16 PM   #12
Now your SURE you didn't get the Matel Slot Car fuse by mistake?
Old 11-11-2008, 04:45 PM   #13
dgbehrends's Avatar
Rewards Points: 150
Yep I'm pretty sure. I think the slot car fuse was a lot more expensive.
D in MN
Old 11-11-2008, 06:09 PM   #14
LOL you did good.
Old 11-11-2008, 07:46 PM   #15
open your pack of cigarettes remove small piece of foil wrap fuse in foil reinstall now your furnace is like 75% of the rest them out there
kennzz05 is offline   Reply With Quote
Fuse Boxes For Showers Petrena Electrical 3 09-13-2008 01:36 AM
Problems with new fuse box for a dryer. needsomehelp Electrical 12 04-10-2008 11:20 PM
Goodman GMT-070-4 Furnace blows 3A Fuse Bruce Mundy HVAC 4 01-02-2008 10:31 PM
Microwave Fuse Replacement - Overbilling Glasnost Electrical 13 11-18-2007 09:27 PM
