Bryant Plus 90 - HVAC - DIY Chatroom Home Improvement Forum
Old 10-29-2008, 09:07 PM   #1
Bryant Plus 90
I Have A Bryant Plus 90 And After The Heat Cycle The Induction Fan Keeps Running Until I Shut Power Off To The Furnace, Then It Stops Till Next Time? Please Help?
MIKE 1969 is offline   Reply With Quote
Old 10-29-2008, 10:21 PM   #2
HvacWiz's Avatar
Rewards Points: 252
There is an inducer control board located behind the presure switch, Reley on that board is most likely sticking. You can try tapping it lightly to get it to stop, but you will need a new inducer board.
HvacWiz is offline   Reply With Quote
Old 10-31-2008, 10:47 AM   #3
Hvacwiz, are you referring to the much older 90s?
Remember the model that the board plugged into the vestibule harness from the blower section? Every have one of those with a short you could't find?
hvaclover is offline   Reply With Quote
Old 11-01-2008, 03:18 AM   #4
HvacWiz's Avatar
Rewards Points: 252
yes I do, I stand corrected.
Bryant 355MAV furnace and A/C blower not starting rajar2 HVAC 39 11-05-2015 02:03 PM
Leaking Condenation Trap - Bryant falcon HVAC 9 04-01-2009 07:17 PM
Burner on Bryant furnace won't come on Flylowflyslow HVAC 1 09-19-2007 01:57 PM
Bryant gas furnace non startup homer12 HVAC 4 12-14-2006 09:30 PM
