Bryant Plus 80 Squealing - HVAC - DIY Chatroom Home Improvement Forum
Old 02-01-2014, 09:13 PM   #1
Rewards Points: 18
Question
Hello all.
I have an older model (1997 I think, came with the home) Bryant Plus 80. It works perfectly fine. We change the filters and i clean out the fan every now and again. A couple days ago I started hearing, randomly, a high pitched squeal. I looked into it and There is a small black wheel that is squealing. I tapped it and it stopped. I believe it is the inducer blower motor. I _think_ the replacement part number is HC21ZE117. However, is there anything that would cause this? is this a symptom or is it the actual problem? See attached pic. it's the small black wheel. I'm also not sure where to find the model number. There seem to be about 1000 stickers with numbers in there.
Thanks!
Jeff
hsnopi is offline   Reply With Quote
Old 02-02-2014, 04:41 AM   #2
An old Tradesmen
Rewards Points: 7,262
The inducer motor's bearing are getting tight and wearing out.
Old 02-02-2014, 07:21 AM   #3
Rewards Points: 582
I 2nd that inducer bearing starting to go ....ben sr
Old 02-02-2014, 07:39 AM   #4
noisey inducer
I cant tell you how many of these I have replaced.....as an inducer motor,it is a very large one,but they sseem to go bad quite often.
seabee570 is offline   Reply With Quote
Old 02-02-2014, 08:47 AM   #5
Hvac Pro
yuri's Avatar
Rewards Points: 2,230
at that age the bearings in the exhaust fan motor will wear out. It is a difficult job to change as you have to remove the fan and replace the squirrel cage wheel in the fan also and it is VERY easy to bend/warp and will vibrate badly later. May want to get a Pro to do it.
Old 02-02-2014, 02:20 PM   #6
Rewards Points: 18
thanks for all the input!
Bryant evaporator coil and using A/C sealant. tampaite HVAC 14 04-19-2013 06:40 AM
Heat pump (Bryant) in CT? desmo907 HVAC 7 07-16-2012 07:09 PM
Squealing water pipes kennelm Plumbing 13 04-22-2012 08:06 AM
Bryant Warranteed heat exchangers issues TruckTahoe HVAC 0 02-14-2011 02:21 PM
first time startup on Bryant furnace - furnace calls for heat and will not stop luvheat HVAC 22 02-14-2009 08:56 AM
