Bryant Plus 09i Won't Shut Off - HVAC - DIY Chatroom Home Improvement Forum
Old 10-22-2011, 04:08 PM   #1
Bryant Plus 09i won't shut off
My Bryant Plus 90i furnace continues to heat on high heat after reaching the set temperature. Replaced the thermostat - no effect. No fault codes. What do I look for?
Bill Strathman is offline   Reply With Quote
Old 10-22-2011, 04:30 PM   #2
how
Rewards Points: 1,100
Are you saying that your house is getting too hot or that a 2 stage is only heating on the second stage?
If its the former..the 1st thing to look for is a short between the thermostat lines somewhere between the mother board and the thermostat on the wall. (worn insulation between both lines or over metal, maretts that are missing on a spliced connection, a nail or staple through both of them, etc.)
how is offline   Reply With Quote
Old 10-22-2011, 06:07 PM   #3
Both stages work - it just keeps pumping out high heat after satisfying the thermostat. I'll check what wiring I can reach - most of it is buried in the walls. Thanks.
Old 10-23-2011, 07:04 PM   #4
I hooked up the thermostat to the furnace with a short wire. Same result - once it starts a heat cycle it won't stop. Turning the thermostat down below room temperature doesn't stop it. Setting the heat-off-cool switch to off doesn't stop it. Anyone have a troubleshooting manual?
Bryant Furnace Blower Won't Shut Off aorozco HVAC 3 12-02-2010 02:20 AM
Shut Off Valve won't shut off DIY_Dumbie Plumbing 1 07-11-2009 03:22 PM
Bryant won't shut off reojim HVAC 1 12-12-2008 11:36 PM
Community water shut off zevon Plumbing 14 10-03-2008 08:16 AM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 12:16 PM
