Bryant Pilot Burner - HVAC - DIY Chatroom Home Improvement Forum
Old 12-06-2008, 08:26 PM   #1
Bryant Pilot Burner
My Bryant gas furnace stopped heating. I explained my problem to the local Bryant dealer and he suggested I replace the Pilot Burner (# LH-33JZ-053). I replaced it, turned it on and it ran good for about a hour and I figured it was fixed (it did seem that the burners was cycling too fast, but didnít know for sure). Didnít need it again for about 2 weeks. Turned it on, pilot is burning but no flames. Went back to the dealer, got another Pilot Burner, same as before. Ran it for an hour everything fine as before tought it was fixed again. Two days later needed heat ,same problem as before only this time the flames comes on, but as soon as the fan kicks on the flames went out didnít light again. This pilot burner has two wires that connect to the gas valve. No other wires connect to the valve. No problem with the pilot staying lite, the valve will not allow gas to the burners. Can anyone help me out on this.
modemjim is offline   Reply With Quote
Old 12-07-2008, 12:32 AM   #2
Pilot gas may need to be increased. Maybe the limit. Try smacking the it or jumping it out.
The limit is that little black box with the word Camstat on it.
hvaclover is offline   Reply With Quote
Old 12-13-2008, 02:17 PM   #3
Replaced the cam-stat, works fine now. Thanks.
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 11:40 AM
Bryant Furnace main burner goes out after 5 seconds Da_Bears HVAC 8 01-03-2012 02:24 AM
comfortmaker pilot lights but not burner jasonzzz HVAC 6 01-28-2008 12:20 PM
heat turns pilot light off tclarkmd HVAC 3 10-12-2007 10:37 AM
Burner on Bryant furnace won't come on Flylowflyslow HVAC 1 09-19-2007 01:57 PM
