bryant model 393-U furnace
a furnace that uses a 2 wire pilot you are better off to replace the furnace IMO
However, yes you can remove the assembly and clean it and the pilot orifice. Best left to a PRO who deals with gas everyday. IMO
Remove the pilot tubing from the gas valve, then remove the tubing and pilot assy as one and then disassemble and clean, then reassemble and check for gas leaks.
IT IS WHAT IT IS To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
